Old 10-01-2021, 08:13 AM   #1
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
4x4 front axial
Bought a 1971 blazer frame don't look like the right axial.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 10-01-2021, 10:10 AM   #2
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 4x4 front axial
What looks wrong to you?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-01-2021, 10:12 AM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 4x4 front axial
An OEM 71 front axle wouldn't have a bracket for the steering damper. The backing plates look different to me too.
Old 10-01-2021, 11:02 AM   #4
Gary 70 Jimmy
Re: 4x4 front axial
Don't look any thing like me 72 jimmy.
Old 10-01-2021, 12:02 PM   #5
MJN
MJN's Avatar
Re: 4x4 front axial
Looks like a late 70's Dana 44 or GM corporate 10 bolt based on the upside down tierod ends, no flat top passenger side knuckle and placement of the steering damper. Also the brake dust shields are heavy gauge steel instead of the sheetmetal used on the early Dana 44's. Post a picture of the differential cover please.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-01-2021, 04:12 PM   #6
Gary 70 Jimmy
Re: 4x4 front axial
Pics
Old 10-04-2021, 09:20 AM   #7
MJN
MJN's Avatar
Re: 4x4 front axial
Its a Dana 44, there is a number stamped on the front of the long axle tube that will tell you the build date- or you can pull the diff cover and get the date from the ring gear as well, along with the ratio.
'17 GMC Yukon XL
VCCA member #58596
Old 10-04-2021, 04:41 PM   #8
Gary 70 Jimmy
Re: 4x4 front axial
Found a tag looks like 373 don't no what 41-11 means.
Old 10-04-2021, 04:50 PM   #9
MJN
MJN's Avatar
Re: 4x4 front axial
41 ring gear teeth
11 pinion teeth
41/11= 3.727 or 3.73 ratio
'17 GMC Yukon XL
VCCA member #58596
Old 10-05-2021, 08:13 PM   #10
Gary 70 Jimmy
Re: 4x4 front axial
Found the date 1-12-76 looks like the caliper my be the same as my 72.
