![]() Join Date: Jul 2015
This Aussiespeed manifold just arrived…
Four barrel intake for the 292 - could be an interesting project.
1963 C20, small window, long bed 292, 4-speed |
Re: This Aussiespeed manifold just arrived…
Could be interesting all right!
You gonna use a mono jet or a 1250 dominator? |
Quadrajet
Looks like an adaptor too, then.
Sideways mount or front/back? |
#6 | |
Anyone know if there are linkages available for this type of setup?
![]() ![]() ![]() Join Date: Jan 2018
If my truck had a 292, I probably would have gone sideways quadrajet. If you use a carb for late 70s 305 (has electric choke and uses a throttle cable), you can mount sideways, use a 71-72 gas pedal, and have a throttle cable that takes the pain out of setting up a linkage system.
I went with that carb on my 283 and it has worked great. I used a 73-87 gas pedal which didn't turn out as great as I was hoping. One day I'll change it to a 71-72 pedal
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Another side note is Ford incorporated a return spring in some of their throttle cables. It sure makes for a neat & clean installation if you go the cable route rather than linkage.
this is for a 71-72 Mustang https://eclassics.com/eclassics-1971...xoC4ysQAvD_BwE I used a 6 cylinder cable on my friends 72 Corvette when he added dual quads. Nice & Clean look that worked flawlessly. |
| Bookmarks |
