Old 07-06-2021, 04:52 PM   #26
tdangle
tdangle's Avatar
Re: Hot Weather, Fuel Injection & 383 Stroker
Keep us up-to-date on how well this is all working for you.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-06-2021, 05:52 PM   #27
body bolt
I'm planning to use the Edelbrock fuel system which runs only a vent back to ththe tank. That way I can use the vapor vent line that is already there. This is my plan but you know how plans are.
Originally Posted by my67c20 View Post
I did think about a return system and also thought about going to an electric pump, but when i had the reoccurring issue with leaking bowl gaskets, it was enough to push me over the edge. Had no issues in the midwest, but in this heat rubber and fuel do not stay stable.
body bolt is offline   Reply With Quote
Old 07-07-2021, 07:28 AM   #28
biketopia
Excellent, I have a sniper on my Camaro. That 427 SBC will be coming out and going in the C10 with the sniper as well. I love it so far, from what little I've driven it. Was fighting some RFI issues at first but I got those cleaned up with some better wiring. I think you'll really like it!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 07-07-2021, 09:47 AM   #29
Richard2112
Richard2112's Avatar
The recommendation of a better HEI module is interesting. Not something that would've come to mind immediately.
Richard2112 is offline   Reply With Quote
Old 10-07-2021, 08:29 AM   #30
70STOVEBOLT
70STOVEBOLT's Avatar
(long read) If you made it this far, thanks for reading and if you have questions let me know.
What is the diameter of the clamps for the o2 sensor? I am close to pulling the trigger on one of the master kits, but I want to order everything I need at once so I don't have to run back and forth to the parts store. I have 2 1/2" exhaust.
Thanks for the write up and review.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-07-2021, 11:22 AM   #31
my67c20
The master kit comes with the clamps. I believe my exhaust to be 2.5" and the clamps worked out just fine. Anything smaller and you might have an issue getting the clamps tight. Only stuff I was extra wiring, hard fuel line and some different angled fittings. Probably could have used everything hte kit had to offer, but did not want it to look messy
my67c20 is offline   Reply With Quote
Old 10-07-2021, 11:24 AM   #32
my67c20
Oh, and so far loving it. Nice to turn the key and have it fire right up. Only tweak has been the idle.
Old 10-07-2021, 12:15 PM   #33
jimijam00
More proof that people thinking Snipers don't work in hot weather climates are wrong.
jimijam00 is offline   Reply With Quote
Old 10-07-2021, 12:40 PM   #34
70STOVEBOLT
Thank you for the response.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 10-07-2021, 01:44 PM   #35
my67c20
It really "boils" down to fuel recycling. I could have put a simple return system with the carb, but with the mechanical pump its only of value when cranking or running. I could have switched to an electric pump, but now I am getting closer to fuel injection, so why not go all in.
The other benefit is the throttle response. I know a carb can be tuned, but who has time to deal with that, especially when it is not a daily driver. Plus now this thing now gets up and goes.
The next problem to tackle is the underhood temperatures and install some sort of custom cold air intake, so its not breathing 300 degree air.
