#26 |
Re: Hot Weather, Fuel Injection & 383 Stroker
Keep us up-to-date on how well this is all working for you.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#27 | |
I'm planning to use the Edelbrock fuel system which runs only a vent back to ththe tank. That way I can use the vapor vent line that is already there. This is my plan but you know how plans are.
#28 |
![]() Join Date: Jul 2015
Excellent, I have a sniper on my Camaro. That 427 SBC will be coming out and going in the C10 with the sniper as well. I love it so far, from what little I've driven it. Was fighting some RFI issues at first but I got those cleaned up with some better wiring. I think you'll really like it!
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#29 |
The recommendation of a better HEI module is interesting. Not something that would've come to mind immediately.
#30 | |
![]() Join Date: Jun 2005
Thanks for the write up and review.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#31 |
The master kit comes with the clamps. I believe my exhaust to be 2.5" and the clamps worked out just fine. Anything smaller and you might have an issue getting the clamps tight. Only stuff I was extra wiring, hard fuel line and some different angled fittings. Probably could have used everything hte kit had to offer, but did not want it to look messy
#32 |
Oh, and so far loving it. Nice to turn the key and have it fire right up. Only tweak has been the idle.
#33 |
More proof that people thinking Snipers don't work in hot weather climates are wrong.
#34 |
Thank you for the response.
#35 | |
The other benefit is the throttle response. I know a carb can be tuned, but who has time to deal with that, especially when it is not a daily driver. Plus now this thing now gets up and goes. The next problem to tackle is the underhood temperatures and install some sort of custom cold air intake, so its not breathing 300 degree air. |
