Old 10-08-2021, 08:49 AM   #1
GMC71k20
Holley Gas tank install questions
Has anyone installed the Holley Gas tank part #19-185
https://www.holley.com/products/fuel...s/parts/19-185
I have it ready to install but was hoping to hear from someone that installed it before
I believe I can cut off the two rear frame cross members and bolt it to the upper part of the frame. Anyone done this before?
Also, how does the gas fill line up in relation to the wood floor? Hoping it's not below a metal strip
Thanks in advance
Also, Didn't see anyone posts about this tank so I'll post an install thread as I go along
GMC71k20 is offline   Reply With Quote
Old 10-08-2021, 12:10 PM   #2
Mbeef61
Mbeef61's Avatar
Re: Holley Gas tank install questions
I only cut out the spare tire mount. No crossmembers. Looks up Boyd tank installs. It’s the same thing
Mbeef61 is offline   Reply With Quote
Old 10-08-2021, 01:06 PM   #3
67C10Step
67C10Step's Avatar
I can only advise to a Boyd's install. Easy as pie. I was concerned about where the filler would fall as well but Boyd's obviously has this all figured out.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-08-2021, 09:56 PM   #4
GMC71k20
Thanks for replying everyone, it helped me realize I was sent the wrong tank
MBeef is right, very similar. I'd say Boyds looks better though
67C10step, where did you get that fuel door? I like the set up and thanks for sharing
Old 10-09-2021, 09:07 AM   #5
old51sedan
old51sedan's Avatar
I guess there are several different ways to do certain things including mounting not only the tank, but the filler also. He is how I did mine, just another way.
old51sedan is offline   Reply With Quote
Old 10-09-2021, 10:51 AM   #6
67C10Step
67C10Step's Avatar
I got my cap from Boyd’s as well. I like the one old51 showed as well but don’t know if I have the skills for that level.
My tank is set up for carburetor now but I went ahead and ran a supply and return line just in case while I was running a new hard line from the rear to the front.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
