Old 07-19-2004, 01:18 AM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
lift kits
What do you have to do to a first gen blazer after you install a 9 or 10 inch suspension lift kit on it? Do the driveshafts have to be lengthened? The differentials cut and turned? Another board member has a 9 inch lift with 39 inch tires and I think that looks awesome! Any help would be appreciated.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 07-19-2004, 11:16 AM   #2
redz 1970 K5
OBS guy
redz 1970 K5's Avatar
Pinion angles are going to be a MO-FO with a Blazer at those lift heights... Drivelines will need lengthening for sure... For that kind of lift, you are going to have to cut and turn the diffs to get a decent pinion angle.
6" is borderline, 8" is pushing it, and 10" is definitely going to take some work...
Why not a 6" Suspension and 3" Body? That will get you 38's or 39's x 14-15" wide on a 12" rim...
redz 1970 K5 is offline   Reply With Quote
Old 07-19-2004, 11:24 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You could also go with some High angle Drivelines (http://highangledriveline.com/).
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 07-19-2004, 12:38 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I have 6 inch suspention and 3 inch body. 38's barely fit if you like to offroad. they do rub alot. that is on a 10 inch wide wheel so any wider would be a big problem. If you want tires that big I would get 8 inch suspention and 2-3 inches of body. I really need 11 I think. That is with a true 38 though. If you buy a Ground Hawg, they run closer to 36 inches.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 07-20-2004, 03:14 AM   #5
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Hey 2wdBlazer,
It was your truck that I saw. I love the look of it. That is how I would want mine to look. 6 inch suspension and 3 inch body is all you had to do? Thanks again for the help.
Old 07-20-2004, 03:32 AM   #6
71 Blazer CST man
71 Blazer CST man's Avatar
guess you fooled ^him^ 2wdblazer , hahahah
71 Blazer CST man is offline   Reply With Quote
Old 07-20-2004, 10:51 AM   #7
2wdBlazer
The Blazer King
2wdBlazer's Avatar
What????
Bad_turbo: My front driveshaft is VERY extended and I would recommend to get it made longer.
Old 07-20-2004, 04:17 PM   #8
71 Blazer CST man
it would seem BT thought you had a "9 or 10 inch suspension lift kit" cuz that's what he said he likes, then once ya posted he said its infact YOUR truck he saw that's sick! But yours is only a 6"(3body). - *ya fooled him* kinda
Old 07-20-2004, 04:41 PM   #9
2wdBlazer
The Blazer King
2wdBlazer's Avatar
ah ha. I see now.
