Rear Hatch Hardware Pictures????
I have been driving my Blazer around for about thirteen years with the rear hatch bouncing back and forth because all of the hardware was missing when I bought it. Last week I bought all of the rear hatch hardware. Now that I have it, I am not sure how it all goes together. Does anyone have pictures from the T-handle to the ends? I think I can figure out the T-handle and support bracket, rods and latches, but there are two other small parts that are not the same that I don't have a clue as to where they go. Any pics or ideas will be greatly appreciated. Thanks David
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Rear Hatch Hardware Pictures????
here are some of the handle area.Sorry..no pic's of the latch's on each side.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Thanks Bobby! That part I have figured out. I will try to post pictures tomorrow of the two pieces that I am unsure of, unless someone else posts more pictures beforehand.
Just need a couple more parts.
Nice job with the kotter pins to hold the arms. I looked all over for the actual clips to hold them in place. I finally found some at a chev dealer in a small town that had stock still from years back. I only bought 1/2 dozen and should have bought all of them.
--------------------------------------------------- 1947 Studebaker M5 project to match the camping trailer. 1950 Chev 4x4 Pickup 1958 Shasta Airflyte Travel trailer (fresh restoration) 1971 C/10 Pickup(Frame off Restoration) 1972 K5 Blazer CST (Daily Driver & My Company Truck) 1976 Honda CB750 Bobber 1988 Jaguar XJ12 |
The LuvShack Garage
The spring loaded ends clampy thingamajiggers
![]() (2 pairs of them on the right hand side of this pic)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
To the left of the springloaded thingymajiggers, above the T-handle spring thingymajigger. I hope I spelled thingymajigger correct. Thanks David
The LuvShack Garage
Well then, maybe these will help
Thanks! That helps tremendously. One last question, In your photograph, there are two identical pieces above the T-handle spring thingymajigger and there is one piece to the left that is almost identical, but smaller. In the set that I bought, I have one large piece and one of the small pieces, Is this correct and if so, which goes on which side or did evil bay get me and I got a mismatched set? Thanks again!!! David
Those cover the bolts on the latch mechanism.
![]() ![]() The smaller rubber tipped ones are bumpers and go here(I didn't reinstall mine) ![]()
VA72C10
![]() Join Date: Mar 2008
this is a GREAT thread that should go into the blazer's/jimmy thread area and FAQ index. Thanks to all that posted as it helped me figure out mine I'm doing today (4 years after the original thread)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
The LuvShack Garage
Holy old f'n thread Batman
VA72C10
Thanks for posting the pictures...were you still subscribed to it???
Active Member
![]() Join Date: Dec 2004
more info, I'm also buying/trading for any of these parts if you have extras
Thanks LUV2XC8 for the pics this will help me as I will be rebuilding my hatch this winter!
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
#15 |
I am also looking at repairing my hatch, if you find a stash, let me know.
#16 |
Back in the sticks
There are pics on this thread of what it looks like when split apart:
http://67-72chevytrucks.com/vboard/s...d.php?t=403730
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#17 |
Where Can I purchase the rear hatch hardware? I just got a 1971 Blazer but it has no hardware installed, in fact some had fiberglassed in the outside holes.
#18 |
Almost all have to be purchased original.
OEM originals are very hard to find because there are reproductions(repops) of only a few different parts. Most there are no reproductions. So demand with low supply Use the Parts Board on this Forum. There is a center mechanism there right now!!!! You need to buy quickly on the Parts Board, or you will lose out to the others. I just went through this for along time. Because I am restoring a 72 GMC Jimmy. Will do some other responses later with more info. Terry |
#19 |
which parts exactly are needed? I have some that I'm not using...
'72 K5, known as 'the Fox.' |
#20 | |
Thanks in advance Nevermind. Looked at the pic closer, you can tell they’re both up! Last edited by bsantino; 10-14-2021 at 09:31 AM. |
