10-02-2021, 05:22 PM | #1 |
aftermarket tranny x member opinions
I bought one of those "Performance" Square tubed x members from GMC Pauls for my transmission thinking it might be beneficial with my new 421SBC installation.
However sizing it up today for installation I find it is around 1/2 inch to short between the frame rails and the bolt holes do not line up, plus it is not centered for the tranny mount. It is a nice heavy piece however it does not quite match the pic on the website as well...... Now i am thinking of just putting a few welds on my factory x member to reinforce the rivets and then just painting and reinstalling. What do you guys think?? Any benefit over the stock piece for performance and strength????
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
10-02-2021, 07:34 PM | #2 |
Re: aftermarket tranny x member opinions
Can't help you too much with the tranny crossmember. I took out an IFS (Ingenuity Fab and Speed) crossmember that worked well that the previous owner installed (they have been out of stock for a new one for a while now), and installed a TW Fab one which is remarkably beefy (and everything lined up perfectly).
What are the details on the 421 your building?! I've been kicking around that idea myself as well! |
10-02-2021, 07:45 PM | #3 |
See if GForce makes one for the C10. I got one of theirs in the Chevelle.
10-02-2021, 07:55 PM | #4 |
What are the details on the 421 your building?! I've been kicking around that idea myself as well![/QUOTE]
I bought a deluxe short-block from Nyes Racing in Muncie,In comes with a Dart SHP block, Eagle rotating assembly, SRP Pistons 10.5:1 , comp cam 237/246 520/530 lift with 113 LSA . and I am waiting on a set of heads from Eric Weingartner out of oklahoma. His 195 profilers ported out to 213 CC . I wanted to go down on the duration slightly around 233/241 and have a 112LSA but Pat McCreery said his cam grinder can not get roller cores. Normally they have Erson custom grinds. So he finally found me a on the shelf comp piece
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks Last edited by bigmac73; 10-02-2021 at 07:56 PM. Reason: my grammer sucks |
10-02-2021, 08:00 PM | #5 |
if i google TW fab i get a hummer website???
10-02-2021, 08:03 PM | #6 |
If you are lucky
10-02-2021, 08:09 PM | #7 |
G force does make them for a C10
10-02-2021, 08:26 PM | #8 |
I'd buy it if I needed one for my C10. The one in my Chevelle fits like a glove and the 3" exhaust goes right through it.
10-02-2021, 08:33 PM | #9 |
At the body shop.
Pull the rail in with a ratchet strap.
The oem frames are super flexible. And move a bunch
" That didnt make it any newer " " Dont antique the equipment " |
10-03-2021, 01:43 AM | #10 |
10-03-2021, 07:40 AM | #11 |
i might try it.However I matched it up with my factory member and it is defiantly shorter.
10-03-2021, 07:44 AM | #12 |
I am shooting for 550 Torque, I told Pat i was not concerned about the HP . If you get the TQ numbers up the HP will follow suit. And I do not really plan on taking it higher that 5800RPM's
10-03-2021, 10:57 AM | #13 |
Have you talked to GMC Paul's about this? Confirm you got the right part?
72 C10 lwb fleetside -stock 350/350 combo |
10-03-2021, 01:46 PM | #14 |
No i have not this thing has been sittinf in my garage for about 6 month or.longer. i cant even find the receipt.
10-09-2021, 11:36 AM | #15 | |
going to give them a call and see what is up
10-09-2021, 08:11 PM | #16 |
I really like the Holley Blackheart crossmember
10-15-2021, 10:21 AM | #17 |
I will take a look
