Old 10-10-2021, 08:38 PM   #1
Nick2x2x
Nick2x2x's Avatar
Ignition switch getting hot!
Have a 1970 C10 LSSwap with American Autowire wiring harness noticed this weekend that hot wire is getting extremely hot. Anyone have any idea why this may be happening?
Nick2x2x is offline   Reply With Quote
Old 10-10-2021, 08:47 PM   #2
davischevy
davischevy's Avatar
Re: Ignition switch getting hot!
Check your grounds.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-11-2021, 09:57 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Like Larry said the grounds would be a good place to start. Here is a good thread on the ground strap locations. They are really important on these trucks.
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
It could also be a weak ignition switch or dirty terminals on the switch its self.
LockDoc
Leon
Old 10-11-2021, 10:42 AM   #4
body bolt
Like LockDoc said, I'd check the switch. Bad grounds wouldn't cause the hot wire to get hot.
body bolt is offline   Reply With Quote
Old 10-11-2021, 11:03 AM   #5
HotWheelsFan
HotWheelsFan's Avatar
Heat comes from resistance, usually...
A poor connection from the wires to the switch, through the connection or the terminals. Worn switch causing poor connections internally. Problem could be elsewhere in the circuit as well, allowing added current through the switch.
I have seen these common problems with older vehicles as rust and corrosion attacks electrical systems. A little resistance at every terminal adds up.
Maybe amp draw testing or voltage drop testing could help pinpoint where the problem is.
Bob
HotWheelsFan is offline   Reply With Quote
Old 10-11-2021, 11:39 AM   #6
fun in dirt
fun in dirt's Avatar
Check the connectors in the plug that goes into the switch. As much as I like American Autowire, the last ign switch connector I got in a kit had a loose terminal that almost caused a big problem.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 10-11-2021, 03:04 PM   #7
HO455
HO455's Avatar
Here is a thread on ignition switch issues I have experienced.
I would suggest doing amperage checks on individual conductors with a clamp on style ampmeter. Only turning the power on long enough to get a reading then power off before changing conductors. You want to avoid damaging anything. Start with the power supply to switch.
Something is drawing too much amperage! It could be from a bad ignition switch or as this is a new installation there may be a wire that is somehow partially grounded causing the increased amp draw.
Don't assume that the harness or any other new component is not at fault. AAW makes good products (Heck I have an AAW harness on my Burban.) but, anybody can have a bad day.
Does the problem occur in both ON and ACC? Or is it in START only? Answering these should help us help you find the problem.
Do you know if the harness uses the original color coding the factory used ?
https://67-72chevytrucks.com/vboard/...d.php?t=818861
Good luck and keep us posted.
RIP Bob Parks.
Old 10-11-2021, 05:02 PM   #8
Wrenchbender Ret
It is common on these trucks. You are going to have to replace the switch & connector pigtail. They are readily available. Do you know how to remove the tumbler from the switch? The best way to connect the wires to the pigtail is solder & heat shrink tubing.
George
Wrenchbender Ret is offline   Reply With Quote
Old 10-11-2021, 08:25 PM   #9
BigBird05
If you have a new ign switch it could be at fault. They are not made as well as the original switch. They can over heat easely. Best to use some relays to protect your wireing.
BigBird05 is offline   Reply With Quote
Old 10-12-2021, 11:59 AM   #10
HotWheelsFan
I'm not sure about soldering the terminals, just a good crimp tool secures the wires fine.
I have tried soldering terminals on one of my projects and had problems with corrosion. It seems the flux in the solder eats away the plating on some terminals allowing corrosion to start.
I have seen posts about pros and cons of soldering automotive terminals.
Just a thought...
Bob
Old 10-12-2021, 01:15 PM   #11
MARKDTN
The AAW kits appear to have a new plug so not sure why you would have to replace it? Even so they are probably type 56 connectors. You can buy the terminals and crimp them on if needed-assuming you have enough wire length. That would avoid a splice. Are you exceeding the current capacity of the wiring? If you have a lot of high amp stuff you may need to supply them using relays that (fused) powered direct to battery and are triggered by an ignition source so you can take load off that ignition switch. But I would start with grounds. Proper grounds are so important and so often overlooked.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 10-12-2021, 10:42 PM   #12
toolboxchev
Is it when the heater is running?
The heater circuit runs through the ignition switch. If you have an AC heater fan which will draw 30 amps or so on high without the AC wiring and relay this could be the culprit.
GM did some funny stuff and now nobody supplies a 10 or 15 amp heater only fan. The parts houses just substitute the AC fan for heater only applications. Ask me how I know, I had to completely rebuild my stock wiring harness due to this, plus switches, plugs and all kinds of stuff.
toolboxchev is offline   Reply With Quote
Old 10-18-2021, 09:10 AM   #13
Nick2x2x
Nick2x2x's Avatar
Sorry Its taken me a while to respond been out of town!
So I noticed it while driving after a while. Pulled my key out it was hot as fire but then payed attention a little more.
No electronics were on except radio. Later that evening I just ran the truck and the switch was still getting hot. Going to reach out to AAW about the switch I haven't done a whole bunch of trouble shooting on it since it is a fresh build with about 1900 miles. For Cruisin the Coast was the longest and the most i driven it at one time which may be why i noticed it there
Old 10-18-2021, 10:39 AM   #14
Accelo
Accelo's Avatar
American Autowire has so many options and places that supply power to other circuits it is impossible to tell what may be going on for sure. You might start with an amp meter on the supply circuit for the switch. I wouldn't blame American Autowire or there products till some basic testing, by someone that know how to troubleshoot electronic circuits, has been completed.
Accelo is offline   Reply With Quote
Old 10-18-2021, 11:50 AM   #15
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Might help....Not "tested" so to speak, I need to install one yet. 1971 with HEI.....
If you haven't already, personally I'd swap out the switch for starts.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 10-18-2021, 05:21 PM   #16
BigBird05
I have torn down original GM switches that are 50+ years old and found that with age the grease gets almost solid and the contact surface between the rotating part of the switch and the fixed contacts that the wires connect to can become very burnt making for a lot of resistance. Enough to melt the connector on the back.
Old 10-18-2021, 09:08 PM   #17
HO455
HO455's Avatar
If you're still driving the truck I certainly hope you have a good fire extinguisher and a battery disconnect on your truck. Problems like this don't just go away. They flare up in a bad way at the worst time.
Pun intended.
RIP Bob Parks.
Old 10-19-2021, 12:24 AM   #18
Accelo
Accelo's Avatar
The kit comes with a new switch.
Old 10-19-2021, 06:22 AM   #19
Nick2x2x
Nick2x2x's Avatar
Pun intended.
No sir haven't driven it at all been busy with work so haven't had much time to troubleshoot.
Old 10-19-2021, 03:05 PM   #20
HO455
HO455's Avatar
Oh good! Your post made me think you had been driving it around.
I definitely understand work taking over ones life.
Good luck when you get time to tear into it. And please post your findings.
RIP Bob Parks.
Old 10-19-2021, 03:23 PM   #21
BigBird05
Dose the switch get hot with the ignition on but not running?
Old 10-20-2021, 02:12 PM   #22
StingRay
StingRay's Avatar
I found out the hard way that a replacement heater motor drew far more current than stock. At first I was thrilled that it would blow a pop can off of the dash. Excellent defrost. Eventually that current draw through the ignition switch caused a melt down.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 10-21-2021, 07:25 AM   #23
Nick2x2x
Nick2x2x's Avatar
UPDATE!!!!!!!!
Was able to do a little investigation!
I used the The ignition Wire (pink) in the AAW wiring harness to feed the Electric fans due to the fans (supposedly) only using 8amps to run! which would have put me at 16 amps total on a a 12ga. wire (rated for 20 amps). Well I have determined that was a LIE! I will be separating the fan feeds and putting 2 inline fuses in and connecting them to the battery link box!
Thank you all for the help glad to be a part of this family!
Old 10-21-2021, 07:58 AM   #24
Accelo
Accelo's Avatar
Glad you identified the issue. Typically fans are powered through relays. This removes the load from the control circuits.
Cheers.
Old 10-21-2021, 01:06 PM   #25
Nick2x2x
Nick2x2x's Avatar
Cheers.
Its actually running through a relay but I pulled the power from a circuit that can't handle the load so I will be going directly to a power source stud
