10-21-2021, 02:50 PM | #1 |
Steering column jacket position?
I'm wondering where the steering jacket should be positioned on the firewall cover. I've seen a few pictures, 1-2 covers are are off the stumps in the jacket (see pic.) and 1-2 rest against the stumps. So I'm pondering over which is right or how much it matters beyond perhaps the shift lever gap and/or the assembly above.
Took a note when I tore it down the cover butts up against the stumps, but that may have been an assumption. My other truck does, but looking at the column it's not a reliable sample. Thanks, pics appreciated though descriptions work too.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
10-21-2021, 02:59 PM | #2 |
Re: Steering column jacket position?
I think those tabs are there to prevent the column from being shoved into your chest during a frontal collision. Many people push the column forward slightly for increased room between the seat and steering wheel. Just not too far so that the slip joint at top of intermediate shaft is bottomed out...otherwise banging and column bearing damage will/can occur.
BTW, yes, the intermediate shaft is a collapsing shaft, but it takes some force to make it collapse, so the tabs keep the column in place. Last edited by Davidf; 10-21-2021 at 04:59 PM. |
10-21-2021, 03:04 PM | #3 |
Subject my other truck, I'm not familiar with this column, maybe because it has a tilt wheel, the truck I'm working on doesn't. But to my knowledge it's supposed to have a washer and spring as well. It shifts well enough, steering alright. EDIT: Tilt columns don't have the spring and washer.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-01-2021 at 11:53 PM. |
10-21-2021, 04:58 PM | #4 | |
10-21-2021, 05:02 PM | #5 | |
The position of your column in your first photo should be fine and still permit travel in the slip joint. Below link is the joint I am talking about: http://67-72chevytrucks.com/vboard/s...d.php?t=420406 Last edited by Davidf; 10-21-2021 at 05:08 PM. |
10-21-2021, 06:13 PM | #6 | |
Got your message on adjusting the mast as well, thanks a bunch. Edit: Got around to reading the service manual. Says "the bracket must not override the protrusions". Now I especially get David's point "Many people push the column forward slightly"
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 10-24-2021 at 01:19 PM. |
