Old 10-21-2021, 05:55 PM   #1
cericd
cericd's Avatar
Radiator Fan Shroud Repair
I have a pretty good sized crack in my radiator shroud. Should I replace or repair it? I've heard that the aftermarket shrouds aren't the best quality of fit. Can it be repaired to function properly as well as look nice?
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 10-21-2021, 06:13 PM   #2
Smitty
Smitty's Avatar
Re: Radiator Fan Shroud Repair
You might research 3M products. They do have some really versatile adhesives that would probably repair that. As for the screen in the previous post. I remember them from the 60’s. Used to prevent rocks and bugs from contacting the radiator. Won’t restrict air flow. So no real reason not to use this vintage piece.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 10-21-2021, 06:14 PM   #3
dmjlambert
dmjlambert's Avatar
Clean the plastic and use the super glue and baking soda trick that Grumpy old man gave info about here. http://67-72chevytrucks.com/vboard/s...d.php?t=791986
That's what I did for mine.
dmjlambert is online now   Reply With Quote
Old 10-21-2021, 07:01 PM   #4
cericd
cericd's Avatar
Thanks. I ran across that thread before I made this post. Do you have any pictures of the area you repaired? I've seen the superglue/baking soda mixture used to repair smaller items like vintage video game and computer cases but nothing this large.
I actually thought of possibly using epoxy to seal the crack then fiberglassing it from the back side for added strength.
Anyone have experience with a particular brand of repop shrouds?
Chris
Old 10-21-2021, 07:28 PM   #5
BigBird05
I wonder if the sonic weld technique that is used on the new facias would work on that.
BigBird05 is offline   Reply With Quote
Old 10-21-2021, 07:47 PM   #6
cericd
cericd's Avatar
I’ll have to look into that. Never heard of it before.
Chris
Old 10-21-2021, 08:40 PM   #7
dmjlambert
dmjlambert's Avatar
Now that I read you first post more carefully I see the "look nice" part of your requirements. Super glue and baking soda does not look nice, it's pretty ugly, it is very functional and makes a super strong plastic.
From what I have read super glue is the glue of choice for plastics and rubber. I suggest clean the area and super glue it and let it dry. It is not a high stress area like the mounting ears, so it will probably hold with just the super glue. To make it extra strong you could use the super glue and baking soda on the back side.
Name:  2021-10-21 19.24.49.jpg
Name:  2021-10-21 19.25.22.jpg
Here is the other ear where I sanded it and used a black magic marker on it to make it look better. So it is possible to pretty it up.
Name:  2021-10-21 19.26.10.jpg
Old 10-21-2021, 09:06 PM   #8
cericd
cericd's Avatar
Thanks for the pics. Looks pretty solid.
Chris
