Old 10-05-2021, 08:39 AM   #301
6DoF
6DoF's Avatar
Re: Project: Tow-Rat (Lil' Blue)
BUT!!! i also got some work on the 55 done too!
i got into the heat exchanger cage last night, and i'm pretty happy with how it's going. still need to make the frame mount tubes, and fully weld it, along with weld in the nuts to bolt on the top plate ... but it's coming together.
cutting off the weak little mounting tabs from the coolers was annoying, along with having to smooth a bunch of super globby welds ... AL dust makes so much more mess ... but we should be good.
6DoF is offline   Reply With Quote
Old 10-05-2021, 03:14 PM   #302
daddyjeep
daddyjeep's Avatar
Originally Posted by 6DoF View Post
i found another distraction!! uuugghhh
this time in the form of what took me YEARS to find. Clean, 2dr, 2000-2001, 6cyl, patriot blue, Jeep Cherokee. has an auto, needs a manual, but i'll take care of that easy enough right now. got it from a buddy for a great deal cuz the head was cracked due to a freeze plug behind the flywheel rusting thru. since the trans has to come out to fix that, i'm picking up a 5spd donor jeep tonight.
So why did you NEED that? Dirt Riot series car or something cool like that?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 10-05-2021, 07:51 PM   #303
daveshilling
daveshilling's Avatar
Awesome! And using your custom mount no less. This will forever be "your" truck no matter who owns it in the future.
daveshilling is offline   Reply With Quote
Old 10-06-2021, 09:24 AM   #304
youngrodder
youngrodder's Avatar
Looks like you know what your doing. Looks great!!
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-07-2021, 07:44 AM   #305
6DoF
6DoF's Avatar
Why did i NEED it? cuz i <3 XJ's, that's why!
will be a daily / winter ride after a she's dialed in a bit. get it running right, 5spd, find any other needed maintenance bits, 3" lift and 32" ATs for the mechanical. then seat heaters, wireless android auto head unit, and remote start, already has power windows n locks. without question i'd rather drive that than anything on the market today. even more so when you think about the $$
Old 10-07-2021, 08:46 AM   #306
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks very clean, nice score. Those exchangers and mount look nice.
Ryan
1969 Chevy milk truck
Old 10-07-2021, 11:36 AM   #307
daddyjeep
daddyjeep's Avatar
Race car would be way cooler, but I get your plan. It will make a solid driver.
04 1500 crew cab
Old 10-22-2021, 10:21 AM   #308
6DoF
6DoF's Avatar
fun was had ... things happened ...
Old 10-22-2021, 10:26 AM   #309
6DoF
6DoF's Avatar
got back to some parts manufacturing though too. made the 10 seat belt nut washers to hold the lab and shoulder belt brackets. i guess i didn't need to do that til the cab is back on the chassis, but i was enjoying welding. got a bunch of bracket tabs made for future proofing the chassis to run hoses n wires with. lined a few down each side of the frame in case i ever want to bolt anything on later. and the heat exchanger cage and mounts are almost ready to weld in. the cage is done, the mounting tubes have been capped with captured nuts, just need to cut the tubes to length and glue em in. after that's mounted i want some ziptie tabs and call it ready for paint.
Old 10-22-2021, 10:30 AM   #310
dsraven
Ok, now you're just showing off.
Looks great, I'm jealous of your tool bin. When I need to make stuff like that it's a drill and a file, lol.
Old 10-22-2021, 12:35 PM   #311
6DoF
6DoF's Avatar
a buddy with the CNC plasma tables makes a woooorrrrrllllddd of difference!
the SWAG press brake for the HF arbor press has been awesome though. did great with the floor, and stuff like these little tabs are a breeze.
Old 10-22-2021, 01:14 PM   #312
dsraven
nice spring you have there. was that a fun trip trying to steer that one to a stop?
Old 10-22-2021, 01:27 PM   #313
daddyjeep
daddyjeep's Avatar
I am amazed at how often I use the press brake that I built for my shop press. If I only had a plasma table.........
04 1500 crew cab
Old 10-22-2021, 01:49 PM   #314
6DoF
6DoF's Avatar
i didn't even notice it!! it could have been broken all day, could have broken in the trailer on the ride home, no clue. was washing it in the driveway spraying everything off ... "um ... sh!t ..."
Old 10-23-2021, 07:58 AM   #315
Dieselwrencher
Nice parts making and that spring is nuts. It almost looks cut with a torch.
Ryan
Old 10-27-2021, 11:55 PM   #316
lower50's
lower50's's Avatar
Nice cage bracket! I assume you have double wrapped springs. WOW
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 10-28-2021, 06:54 AM   #317
6DoF
6DoF's Avatar
for offroad the only thing i'll run is full military wrap, having 2 main leaves means redundancy in an already simple and reliable solution. i think my new springs have finally shipped at least!. it's going to be a guessing game of mix n match with old and new secondary leaves, but first i have ot know how much taller new springs will be
Old 10-28-2021, 07:12 AM   #318
6DoF
6DoF's Avatar
but first, more real updates on the 55! last night i finished the cage mounts and got the whole mess into the chassis. wish i had gotten a picture of trying to prop it up into place, had straps n blocks on stools, was a contraption for sure. and of course, being me, i had to get it within 1/32" of my 3D :facepalm:
so the heat exchangers are still loose-ish in the cage, i built it slightly over-size to allow for a small padded seat AL to Steel. this also allows for a little flex in the mount with the chassis, hopefully without damaging anything.
Old 10-28-2021, 07:18 AM   #319
6DoF
6DoF's Avatar
then this morning i was woke up by a flappy noise in my ductwork ... been there for a few weeks now, but finally pissed me off. got up, got a ladder, pulled the vent and dug some tape out at an arms length in there. but it's gone.
still not time for work ... so i decided to sand the firewall filler and do a quick 3rd glaze on 2 spots cuz i kept leaving weirdness and over sanding.
still not time for work ... so i finished fully welding the post mounts for the heat exchanger cage.
still not time for work ... but this time i went anyways
Old 10-28-2021, 07:56 AM   #320
Father&son56project
That is gorgeous fabrication work!
Father&son56project is offline   Reply With Quote
Old 10-28-2021, 08:08 AM   #321
youngrodder
Nice us of your time....I cant wait to see this one come together....Hurry up, would ya!!
Marc
Old 10-28-2021, 08:58 AM   #322
6DoF
6DoF's Avatar
Marc
cross your fingers for me, i really want to try painting very soon before the weather gets any colder!
Old 10-28-2021, 11:40 AM   #323
daddyjeep
daddyjeep's Avatar
LOL.... good stuff right there.
04 1500 crew cab
Old 10-29-2021, 06:50 AM   #324
6DoF
6DoF's Avatar
BOOM! DONE!
i mean, as done as it's going to be until after assembly. the chassis is still missing f/r bumper mounts and rear hitch receiver. things that i need the bed on to get a complete look at to know where they go. to this point i've only confirmed that i'm pretty sure the bed will somehow fit if i cut some things up a bit, haha.
the big add last night was the Zip-Tie tabs, 39 in total. i had 31 welded to the chassis before i thought ... "i should check and make sure a ziptie fits in these". also kind of detailed out the other bits in prep for paint. one more fancy plate got holes drilled, and the LCA's got drain/rock escape holes on the back edge of the bag pockets. front edge will still push gravel if needed, but the back i wanted stuff to be able to get out.
Old 10-29-2021, 09:00 AM   #325
youngrodder
Great idea on those tabs. You can never have enough zip tie attachment points. That chassis is unreal.
Keep it up
Marc
