Old 01-30-2018, 06:07 PM   #1
panhead59
rear window trim ?
I know there are two different widths of the groove on front/rear windshield trim. I have some trim but don't know which one it is. Anybody have a measurement of the two widths that goes into the rubber seal? Mine looks to be 1\/2-5/8".
panhead59 is offline   Reply With Quote
Old 01-30-2018, 08:44 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: rear window trim ?
The deep trim and shallow trim windshield and rear window gaskets look the same on the outside and the years will interchange as long as you have the correct gasket for the trim you have. The ’71/‘72 shallow trim has a 3/8 lip on it and uses the shallow groove gaskets, and the ’67/’70 deep trim has a 5/8 lip on it and uses the deep groove gaskets. In my experience the gasket with the deep trim is easier to install..... Put the gasket on the glass, then put the trim in the gasket, and install as a unit. You may have to put a few strips of masking tape around it to hold everything together until you are ready to install it.
I wouldn't buy the repo trim. From what I read it doesn't fit too well and makes the windshield almost impossible to install.
LockDoc
Leon
Old 01-30-2018, 08:48 PM   #3
panhead59
Thank you sir That's just what I needed to know
Old 01-31-2018, 07:08 AM   #4
randy.powell
So I've been chasing the issue "why doesn't aftermarket windshield trim fit" for a long time? So - I have 2 sets of oem windshield trim, placed them next to the aftermarket trim, and guess what. The curvature on the aftermarket crap is nowhere close to the oem trim. Especially on the upper long piece! If I knew how to post pics it would be very easy to see why the aftermarket crap continues to be such a nightmare for everyone. With the way it's formed, there is no way it will flex to get it to fit properly.
You can see easily what I'm talking about by taking the long upper piece and placing it on the cab where it goes (before seal and windshield are put in place). No wonder it doesn't work!!!
I've compared the 67-70 trim, 71-72 trim both aftermarket and oem and the results are the same!
Don't waste your time and money. Find the oem trim...
B/R,
Randy
randy.powell is offline   Reply With Quote
Old 01-31-2018, 11:18 PM   #5
CC69Rat
CC69Rat's Avatar
Aftermarket crap here.. it just takes patience.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-31-2018, 11:33 PM   #6
Rufas
Rufas's Avatar
I just went through this last weekend with the trim on my front windshield. After installing/removing the windshield four times I said screw it!
I have a trimless gasket (Precision) on order and hope to install the windshield again this weekend.
BTW window trim was from LMC and is pure C&@P!
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 01-31-2018, 11:44 PM   #7
CC69Rat
CC69Rat's Avatar
Trimparts 67-70 trim, precision gasket + KY .. Yes, KY jelly around the pinch weld and cab. Also, ky in the windshield part of the gasket grove. NOT the trim grove of course. Qtips work nicely to get it into the grove the windshield sits in. The key being the glass has to shift around a little in the gasket as you rope it in. If it's not able to move it will bind, roll under, and pops the trim loose on the corners.
I wouldn't call it easy still,.. but KY helps a bunch. Its water based too, no issues with petroleum based lubes, spray soap you cant control, it won't drip all over your dash. Try it..
Chad
Old 10-30-2021, 01:26 PM   #8
cj847
cj847's Avatar
Can anyone confirm that the rear window stainless trim from a factory rear slider is the same as for the solid glass? Thanks.
cj847 is offline   Reply With Quote
Old 10-31-2021, 03:00 AM   #9
Jblackie47803
Me buying KY jelly at the pharmacy: It's for my windshield, I swear.
Jblackie47803 is offline   Reply With Quote
Old 10-31-2021, 12:06 PM   #10
LockDoc
LockDoc's Avatar
I can't remember for sure. It's been too long. If it uses the same gasket it would use the same trim.
LockDoc
Leon
