11-02-2021, 08:55 PM | #1 |
Frame vin decoder
I bought a frame to swap under my 65 and cant seem to decode the vin. Number on the frame is 6A120287
11-02-2021, 09:13 PM | #2 |
Moderator
Re: Frame vin decoder
Is it a Canadian frame? https://67-72chevytrucks.com/vboard/...84&postcount=2
11-02-2021, 09:42 PM | #3 |
I have no idea I bought it from a guy in Mississippi and it had a 64-66 cab on it is all I know.
11-03-2021, 12:11 AM | #4 |
My truck has a partial vin on the frame that matches the cab. I can't remember what number comes first, but I can check again tomorrow
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-03-2021, 06:58 AM | #5 |
Moderator
Plant designation for Chevrolet on our trucks, GMC may be different.
Wait - a 72 Burb I see had a last numbers of 2Fxxxxxx, maybe it's a 76 built in Atlanta? Mikemelton - Post a couple pics of the frame please.
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 11-03-2021 at 07:23 AM. |
11-03-2021, 12:28 PM | #6 |
This is the only one I have before taking it apart and adding 86 suspension
11-03-2021, 12:33 PM | #7 |
Starting rebuild
11-03-2021, 02:18 PM | #8 |
Moderator
It's a latter model unit with that trans cross member and a-frame bushings. My guess is a 76 built in Atlanta, the last six number are the sequence numbers.
11-03-2021, 05:04 PM | #9 |
11-03-2021, 05:05 PM | #10 |
I know it has ‘86 belly Pan and front suspension on it I put that on it
11-03-2021, 05:18 PM | #11 |
Moderator
That's where your throwing us off. Post a pic of the numbers your quoting in post #1 on the frame.
11-03-2021, 05:53 PM | #12 |
This is stamped in it 6A12028
11-03-2021, 06:18 PM | #13 |
Moderator
No, not with that VIN stamp.
Does a 66 bumber fit on the front frame rails? And were they welded on there?
11-03-2021, 06:28 PM | #14 |
Yes bumper fits nothing has been modified until I got it
11-03-2021, 07:18 PM | #15 |
My guess is you have a 66 frame that was made in Atlanta. The numbers after the A would have matched with the serial numbers on the cab vin.
My truck is a 63 built in Atlanta, so the frame vin is 3A124779. Those last 6 numbers match to the last 6 numbers of my VIN, so I know my original cab is sitting on the original frame
11-03-2021, 07:37 PM | #16 |
Moderator
Yes mine is a 64 with a 4S218076 number on it. I dont know why I didnt just look at mine.
I drink in the morning so...
