Old 11-06-2021, 10:46 AM   #1926
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Originally Posted by Indian113 View Post
Whew! Sure is Pretty, keep up the good work
Thanks Ray, it's getting there...Jim
oldman3 is offline   Reply With Quote
Old 11-06-2021, 11:33 AM   #1927
Tempest67
Tempest67's Avatar
very nice and clean looking.
No pressure, but I consider this truck is an Icon, and all eyes are watching
Thanks for sharing
Tempest67 is offline   Reply With Quote
Old 11-06-2021, 02:14 PM   #1928
Dave_The_BMXER
LS power! Love those coil overs, what make are they? I have the Holley ones, but they're composite.
For people asking about the Intake, Fitech makes one that looks nearly the same as well. Along with a bunch of other companies. Such a visual improvement over factory!
Dave_The_BMXER is offline   Reply With Quote
Old 11-06-2021, 03:38 PM   #1929
oldman3
oldman3's Avatar
Thanks for sharing
Tempest, thank you for the high praise, it's been around for awhile, and different changes over the years. Still a couple more after this...Jim
Thanks Dave, yes several companies offer this style intake Prices from $450 and up. I got coil covers from Speedway for $125.00...Jim
Old 11-08-2021, 09:08 AM   #1930
youngrodder
youngrodder's Avatar
You guys are cranking right along...well done
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-08-2021, 10:49 AM   #1931
oldman3
oldman3's Avatar
Marc
Thank you...Jim
Old 11-10-2021, 02:41 PM   #1932
Indian113
Indian113's Avatar
Jim, you planning on changing your rear gear ratio? I changed mine on my S10 to a 3:73 and still got decent mileage with the OD trans.
Indian113 is offline   Reply With Quote
Old 11-11-2021, 12:36 AM   #1933
oldman3
oldman3's Avatar
Ray, wish it were that simple for me. My Nova rear axle small version only has a series 2 center, can't go to any higher gear ratio. I will need to change my rear axle. It will be done, but later down the road...Jim
Old 11-11-2021, 01:02 AM   #1934
oldman3
oldman3's Avatar
Getting little things done the last couple of days. I worked most of one day making up bracket for the DBW throttle pedal. (see 1st pic).
Mark has most of the wiring all done from BP harness, here's where it is in the cab, will be under the seat (pic 2).
While truck is down, I decided to change the faces on my Speedhut gauges. During dusk time the green numbers were very hard to read and never got as bright as I thought they would. Called Speedhut and they will change all the gauges to a black face with white number, both day and night. Cost will be $80.00 for change. I think I will be happy with this (pic 3).
Received new block hugger headers today and installed. Clearance is great and no more problem with brake arm hitting the header (pic 4).
Still waiting for more parts to arrive, but other things to get done while waiting...Jim
Old 11-11-2021, 03:25 AM   #1935
joedoh
joedoh's Avatar
staggeringly beautiful jim and mark!
Old 11-11-2021, 08:42 AM   #1936
8man
What he said! Thanks for the pics.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 11-11-2021, 08:44 AM   #1937
OutlawDrifter
Making good progress guys!
Making the pedal bracket was time consuming on my '49. I wanted to use the original gas pedal, so it involved a custom arm also.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-11-2021, 09:08 AM   #1938
youngrodder
Jim
After all of these upgrades/changes I bet you enjoy the truck even more than before (if that's possible).
Marc
Old 11-11-2021, 09:53 AM   #1939
mongocanfly
mongocanfly's Avatar
what Marc said X2
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-11-2021, 11:07 AM   #1940
oldman3
oldman3's Avatar
Thanks guys.
Yes it took longer that I thought...Jim
Jim
Marc
Originally Posted by mongocanfly View Post
what Marc said X2
I've always enjoyed the truck, can't wait to see and feel the difference...Jim
Old 11-11-2021, 11:42 AM   #1941
Indian113
Indian113's Avatar
Have you thought off using a Ford Explorer rear end when you changeover? We put a 8.8 under a friend of mines S10 and it is holding up real well. Thee biggest problem is you have to change out the long side for a another short side but with the gear ratios available and abuse they will handle make it worth it.
Old 11-12-2021, 11:34 AM   #1942
lower50's
lower50's's Avatar
Always beautiful work.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-12-2021, 01:50 PM   #1943
oldman3
oldman3's Avatar
Hey Ray, heard good things about them, but I have to stay with a rear axle the same as mine, just need to find a 10 bolt, same width as mine, with 3 series carrier, then check the gear ratio...Jim
Old 11-12-2021, 01:52 PM   #1944
oldman3
oldman3's Avatar
Thanks Bob, appreciate it...Jim
Old 11-13-2021, 11:17 AM   #1945
mongocanfly
Jim, how close is a ZR2 axle to being what you need..has disc brakes and 3.73s with G80
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-13-2021, 11:29 AM   #1946
OutlawDrifter
That's what I run in my '49. I think it will be too wide for Jim's pickup.
1991 Z/28, 6.0L/T56
Old 11-13-2021, 11:29 AM   #1947
oldman3
oldman3's Avatar
Greg, acording to my check the ZR2 is 63", to wide with my wheels.
The S-10 4 wheel drive is 60", that is close to the 60.25 Nova axle I have now.
Thanks for the help...Jim
Old 11-13-2021, 11:58 AM   #1948
mongocanfly
Ok,,I've a got a ZR2 blazer I'm fixing to scrap out...trying to decide what parts to hang onto that can be used..
My Dad has a extended cab S10 4wd that's getting scrapped also..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-19-2021, 12:27 AM   #1949
oldman3
oldman3's Avatar
Hey everyone, been in the shop each day and getting little things done, nothing pic worthly. Been waiting parts, did get stuff in yesterday, and starting using them today.
First pic is the new ICT Billit AC bracket, the first one I had to return wouldn't clear the coil covers, this one fits great. Will remove, scuff and paint it black to match the rest of stuff.
2nd pic is the hook up on the power steering. I installed a low flow valve in the box, then adapter and used the old -6an fittings and lines, hope it works good.
3rd and 4th pic are of the stainless steel exhaust pipes, also new mufflers, flanges, gaskets, etc. Mark and I worked on this today, should finish up tomorrow...Jim
Old 11-19-2021, 08:41 AM   #1950
OutlawDrifter
Jim, would you please share the part number for the ac bracket? ICT makes great stuff, I run a 7176 bracket from them on the LS swap in my Z28.
1991 Z/28, 6.0L/T56
