11-04-2021, 06:07 PM | #1 |
Noisy Belts
https://67-72chevytrucks.com/vboard/...ht=noisy+belts
I just dug this up from the search area. I'm curious to know if anyone else has tried Dielectric grease to their belts to silence them. If so, How much will do the trick? |
11-04-2021, 06:24 PM | #2 |
Re: Noisy Belts
I would think that Dielectric grease would make them more likely to slip. If they are squeaking or screeching you should try V grooved belts.
11-04-2021, 09:13 PM | #3 |
Re: Noisy Belts
I've never tried it but I watched an old guy put a bar of soap to the belts pulley riding surface and it worked.....for how long I do not know.
11-04-2021, 09:16 PM | #4 |
Re: Noisy Belts
X1 ^ it works , Takes the glaze off the pulleys . Just rub a bar of soap on the belts while the engine is off
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
11-04-2021, 10:13 PM | #5 |
Re: Noisy Belts
I just told the People at work this Today
They called me a Used Car Sales man It works
11-05-2021, 02:17 PM | #6 |
Re: Noisy Belts
11-05-2021, 02:18 PM | #7 |
Re: Noisy Belts
11-05-2021, 03:31 PM | #8 |
Re: Noisy Belts
I have used dielectric grease to fix squeaking belt on my 96. Use just a little bit. Baby power works too.
11-05-2021, 05:37 PM | #9 |
Re: Noisy Belts
I was referring to the bar of soap trick
It only last a short while thou.
11-05-2021, 08:50 PM | #10 |
Re: Noisy Belts
Don't be so cheap and go buy a spray can of belt dressing.......
11-06-2021, 04:51 PM | #11 |
20' Daredevil (Ret)
Re: Noisy Belts
I tried that one time, many years ago. Didn't work worth beans, and made a sticky mess that was hard to clean up. Never again. YMMV
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-06-2021, 05:28 PM | #12 |
Re: Noisy Belts
IMHO- Belt dressing is a car salesman stuff.
Save your money. Clean the pulleys and sand them lightly and put a new belt on it. Never fails. The belts with the notches on the inside work better than the smooth ones. They are rated for higher horsepower transmission. They are identified by the same number but have an X as part of the number. |
11-07-2021, 12:57 PM | #13 |
Re: Noisy Belts
11-07-2021, 12:59 PM | #14 |
Re: Noisy Belts
