Old 11-07-2021, 06:04 PM   #1
kev2809
low n' slo
kev2809's Avatar
dirty dingo mounts blocking ground bolt?
I'm either totally missing something here or do these dirty dingo mounts block the driver side ground bolt?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 11-07-2021, 10:04 PM   #2
ls1nova71
ls1nova71's Avatar
Re: dirty dingo mounts blocking ground bolt?
Looks like it is. You should be able to use another threaded hole though. The one below it looks like it would work. I just found out today that a dirty dingo 4x4 front crossmember won't work with the factory brake lines.... You got off easy!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-07-2021, 10:43 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Doesn't look like the engine is in the truck, do a radius clearance for it or use a ARP 12 point bolt or both?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-07-2021, 11:58 PM   #4
sweetk30
sweetk30's Avatar
Had problems with dirty dingo mounts years ago . And he was a real A-HOLE to deal with when i called him out on his crap quality control .
But as said ANY bolt hole will do for a ground point . There not super specific to just 1 spot .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-08-2021, 06:58 PM   #5
pilotXC
Yeah, I had the same issue, very disappointing that there was no communication of that problem.
1972 K20 Cheyanne
1956 VW Bug
LQ4/4L80E Swap: https://67-72chevytrucks.com/vboard/...d.php?t=796095
pilotXC is offline   Reply With Quote
Old 11-08-2021, 06:59 PM   #6
pilotXC
I agree, I called a couple times when I was having some issues and not very friendly or helpful. Seems a few minor adjustments would make it much more user friendly.
1972 K20 Cheyanne
1956 VW Bug
Old 11-08-2021, 08:26 PM   #7
Wgesnerjr
Wgesnerjr's Avatar
a small radius cut will not effect the structural integrity of the mount. It will just make you life easier.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 11-08-2021, 10:19 PM   #8
kev2809
low n' slo
kev2809's Avatar
ya there's no way this bolt goes on without taking a little chunk out of the mounts. I will use the bolt hole below that one. just weird that these don't already come clearanced around that ground bolt hole
-_--_--_ _________
Old 11-08-2021, 11:53 PM   #9
sweetk30
sweetk30's Avatar
Just to clarify my problem . His original slider mounts had welded on tabs . Once blasted in a cabinet before paint i found cold welds . He sent me a 2nd set . . Then same blast before paint and same cold welds . 1 was so bad i could stick a sheet of paper in the gap .
Not long after he offered to buy my silence off i saw he changed the design to a bent tab style .
I told him his attitude and crap welds and wanting to by my silence was not good . . . So i still tell my story as it is and no b/s filler crap .
Old 11-10-2021, 06:36 PM   #10
kev2809
low n' slo
kev2809's Avatar
well the passenger side seems even worse. the motor mount hit the top bolt casting for the ac compressor
-_--_--_ _________
Old 11-13-2021, 01:52 PM   #11
kev2809
low n' slo
kev2809's Avatar
I really need to read the instructions...it does state to trim the passenger side motor mount at the bottom. glad I read it, I was about to grind away at the ac compressor mounting hole
-_--_--_ _________
