Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-26-2021, 06:01 AM   #876
regan wilson
regan wilson's Avatar
Re: Ok Boys and Girls it's Storytime
Thanks LT I'm glad you enjoyed it. This kind of racing is very competitive and can be a challenge for sure. My engine is a little on the extreme side for the class but there are plenty of 1000hp and up powered cars out there too. Although most of them are closer to the 2800lb minimum and I'm at 3550lbs. One of the cool things is I have friends all over the country that I only see at the races.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 10-26-2021, 06:12 AM   #877
regan wilson
Key off.
Key on.
Old 10-30-2021, 09:07 PM   #878
regan wilson
I ripped the cluster back out today. I fixed the speedometer to zero. I also got the the fuel gauge to read closer to my wallet. Just above empty. Lol
Old 10-31-2021, 01:01 AM   #879
mongocanfly
mongocanfly's Avatar
Heck..I thought the 454 speedo was cool..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 10-31-2021, 07:52 AM   #880
regan wilson
The odometer still is on 454. My speedo was stuck on 30mph. I fixed that and managed to get the fuel needle in a more realistic position. Just above empty, kinda like my pockets.
Old 10-31-2021, 08:05 AM   #881
regan wilson
Old 11-02-2021, 11:10 AM   #882
mongocanfly
oh ...i got ya now..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-02-2021, 07:54 PM   #883
regan wilson
I knew that you weren't no Dummy. On the other hand. I hope that your parents are doing ok. i'm looking forward to updates on the Inny.
Old 11-02-2021, 11:53 PM   #884
mongocanfly
Thanks Regan... Dads been in and out of the hospital the last few weeks..hes doing good now..
Appendicitis got him..and a few other health issues..but they're doing good
I did a small update on the "inny" thread..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-03-2021, 05:59 PM   #885
regan wilson
I thought I had a big problem with my new Alternator setup. It just pans out as ignorance on my part. I got a special pulley that uses an HTD belt just like my Dry Sump Pump. I thought it wasn't going to work. After talking to the guys at Jones Racing where it came from. I thought I was going to have to convert to a different alternator. Nope! I go by the Alternator shop this morning. Tada he plucks out the spacer and my pulley fits lol.
Old 11-03-2021, 06:04 PM   #886
regan wilson
This is my new drive setup. It's a 49 tooth on the crank and 22 on the alternator.
Old 11-03-2021, 06:09 PM   #887
regan wilson
It's so cute. Lol Hell I'm glad it will work. I ordered two custom length belts today.
Old 11-03-2021, 08:48 PM   #888
mongocanfly
That's some serious drive power for the alternator.....!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-03-2021, 09:04 PM   #889
regan wilson
The reason behind the overkill is the instant load coming off the trans brake.
Old 11-03-2021, 09:08 PM   #890
regan wilson
I was also turning the alternator too fast with the V belt deal. I couldn’t get a replacement v pulley for my splined drive. So I was kinda forced to adapt.
Old 11-10-2021, 09:27 AM   #891
regan wilson
What do you do when you're bored? Find something to entertain you. I repurposed a header tube from Blue and made a custom exhaust extension for Whitey. This tube had over 160hp running through it. I think it will handle the little 350. Lol
Old 11-10-2021, 10:16 AM   #892
SCOTI
SCOTI's Avatar
The 'feel good' moment that makes you chuckle....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-13-2021, 09:26 PM   #893
regan wilson
Well I took apart this erector set of bars today. Then carried my rearend to my friend Tony. Back in go the 4.56's.
Old 11-13-2021, 09:27 PM   #894
regan wilson
On a side note. Even if you don't have an ATV or a Motorcycle that little jack is pretty handy.
Old 11-13-2021, 09:41 PM   #895
71Dragtruck
71Dragtruck's Avatar
So much easier to just remove a center section, just saying, only thing Ford got right LOL.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 11-13-2021, 10:11 PM   #896
regan wilson
Yes Sir you are correct for sure.
Old 11-19-2021, 06:29 PM   #897
mick53
I went with a Frankland quick change rear end. With my 4:11 ring gear in it I have 128 gear ratios to chose from that I can change in 15 minutes. I think they run from 2.11 to about 8.50 or so. It also looks cool. So there's that. Thank you for your time.
mick53 is offline   Reply With Quote
Old 11-19-2021, 06:39 PM   #898
SCOTI
SCOTI's Avatar
You think a Franklin QC would stand up to the torque load that un-light body, BBC, & those tires slap it with?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-19-2021, 08:13 PM   #899
mick53
It's a QC-80 case from a guy I pitted for when I was young. I took it to the Frankland factory in Pennsylvania and had them build it for 1000 hp. Moser axles. I'm running a Bicknel torque arm with the triple biscuit to take up some of the shock. I had it made to fit my 53 3100 and my 12.88" Wilwood brakes. It's going behind the 1000 hp blown 292 I'm building. we will see which one blows up first.
Old 11-19-2021, 08:20 PM   #900
SCOTI
SCOTI's Avatar
It's a QC-80 case from a guy I pitted for when I was young. I took it to the Frankland factory in Pennsylvania and had them build it for 1000 hp. Moser axles. I'm running a Bicknel torque arm with the triple biscuit to take up some of the shock. I had it made to fit my 53 3100 and my 12.88" Wilwood brakes. I's going behind the 1000 blown 292 I'm building. we will see which one blows up first.
I've always heard of them used in various racing/street apps but not so much in a drag-strip app similar to this. I always assumed they were strong/tough but wasn't sure (didn't know) if they can take the abuse of a heavy vehicle (>3k lbs) & high shock drag-strip venue launches. Appreciate the insight.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
