Old 11-06-2021, 05:46 PM   #1
Husker
Husker's Avatar
Need a seal NP205
I am in need of the seal that goes into the speedo sleeve for a NP205 for my 70 4x4. If any knows part number or that has an extra.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-06-2021, 06:02 PM   #2
roboticjunky
Re: Need a seal NP205
Found this on another site, AC DELCO #326561
roboticjunky is offline   Reply With Quote
Old 11-06-2021, 06:51 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
This might help, there’s another link in this thread that might be useful as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=715463
Tyler
Old 11-06-2021, 07:39 PM   #4
Accelo
Accelo's Avatar
I suspect it's the same seal a used on the automatics?
There are two different sizes there.
If you post the ID and OD I'll look.
Accelo is offline   Reply With Quote
Old 11-06-2021, 08:38 PM   #5
Husker
Husker's Avatar
I did a search and did not come up with any thing relevant like you Gents. I did find the AC Delco one but it was out of stock or discontinued.
Accelo I believe they are the same as Auto's. The one pictured is from my auto.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-06-2021, 09:20 PM   #6
roboticjunky
Here's another seal that looks like the one in the other thread.
https://www.offroaddesign.com/gm-np2...eter-seal.html
Old 11-07-2021, 01:02 AM   #7
Accelo
Accelo's Avatar
"The one pictured is from my auto."
I meant when the speedometer is run from the transmission not the transfer case. Sorry, I can't help without measurements.
Old 11-07-2021, 11:42 AM   #8
Husker
Husker's Avatar
the shaft of the gear where it will sit in seal(rubber)is 13/32"
the opening for seal to go in is 1/2" (outer diameter of seal).
Or very close to these dimensions.
Thanks again everyone.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-07-2021, 12:29 PM   #9
30772
I believe this may be what you're looking for:
https://torqueking.com/product/30065...ransfer-cases/
30772 is offline   Reply With Quote
Old 11-07-2021, 06:24 PM   #10
Accelo
Accelo's Avatar
The OD for the above part is .624 or 5/8
The ID is .375 or 3/8.
Some take the .578 OD. seal.
Which is the seal I have a bunch of.
I'll send you a couple on Monday.
No charge.
The link has the seal for #13.99, an insane price. Then add $11 dollars shipping cost to that.
PM your mailing address.
If they are not correct you need the other size.
Old 11-08-2021, 11:54 AM   #11
Husker
Husker's Avatar
I might be off a bit on measurement. So they might work.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-16-2021, 09:06 PM   #12
Husker
Husker's Avatar
Accelo got the seal today. It was bigger but I got it in ok and put oil in the top side to see if would leak by. Seems to be working good.
Thank You I owe you one.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-17-2021, 08:17 AM   #13
Jcfcamaro
Jcfcamaro's Avatar
Pic. Here is the seal you need.
Jcfcamaro is offline   Reply With Quote
Old 11-17-2021, 08:21 AM   #14
Jcfcamaro
Jcfcamaro's Avatar
SKF is the brand. I bought one at napa, then ordered one off of ebay. 7.00
Old 11-17-2021, 09:29 AM   #15
Husker
Husker's Avatar
Thanks Jcfcamaro appreciate all the help.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
