11-11-2021, 03:13 AM | #1 |
Always on the hunt...
F/S 1972 C10 SB-TH350 two piece driveshaft for LostMy65
Rear two piece driveshaft with center carrier support mounting bracket, setup was removed from a 72 chevy 1/2 ton 2wd long bed with SB350/TH350 and 12 bolt coil rear suspension. $150. picked up/no shipping, giving member LostMy65 first option per recent request (***11/25/21 Update: Setup now available to any interested local buyer***). Thanks for the inquiry, Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... Last edited by Classic Bowties; 11-25-2021 at 11:51 AM. |
11-13-2021, 12:40 AM | #2 |
But Found Her 25yrs Later!
Re: F/S 1972 C10 SB-TH350 two piece driveshaft for LostMy65
Hey thanks,
Could you get me a total length u-joint to very end of the front yoke.
11-13-2021, 01:04 PM | #3 |
Sure, we can get some measurements later this morning but there's really no guesswork here, per your posted inquiry in our other thread this pictured driveshaft was removed from the exact truck model that you had requested. Mel
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
11-14-2021, 12:49 AM | #4 |
When figuring driveshaft measurements we usually use the center to center of u-joint cap method and that dimension would be 71 & 5/8" on center and if measuring per your above request, the overall length is 77 & 3/4" to end of trans slip yoke. Mel
11-14-2021, 05:50 PM | #5 |
Thanks, I'll double check mine.
Sorry for the inconvenience, I'm wanting this for a 65 long bed with a th350. It's not as common the 60-66, but I think the stuff from a 67-72 should be the same.
11-25-2021, 12:04 PM | #6 |
It's been a couple of weeks since first posting, so am now offering driveshaft and carrier mount setup to anyone local that may be interested, no shipping. Thanks, Mel
11-25-2021, 01:36 PM | #7 |
Thanks, Mel. I can't figure why it's not the correct length for a 65 longbed.
From my research: Production 1967–1972 Wheelbase 115 in (2,921 mm) (short box) 127 in (3,226 mm) (long box) 133 in (3,378 mm) (Longhorn . 60-66 C10 115″, 127″. I'll go check again, but yes. I never expected you to hold it for me. . Edit... I think I realized why. The tail on the Th350 can be different lengths. I must have a different th350 than the ones that came in the 67-72.
