Old 03-29-2016, 02:46 PM   #1
61K10
61K10's Avatar
small and big bearing hubs
Question--can you replace dana 44 1973-76 1/2t small bearing spindles with big bearing spindles and hubs?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-29-2016, 07:23 PM   #2
kwmech
Re: small and big bearing hubs
Yes, you will also need a 3/4 ton backing plate/caliper mount
Old 03-29-2016, 08:05 PM   #3
61K10
61K10's Avatar
kwmech--I thought you might know! thanks for posting. new parts are disappearing and the big bearing spindles and hubs can be found new. the small stuff is after market even avl.
1961 chevy K10
Old 03-30-2016, 01:07 PM   #4
61K10
61K10's Avatar
the 3/4t backing plate have a bigger center hole?
1961 chevy K10
Old 03-30-2016, 03:21 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
1/2 ton will work too.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-30-2016, 04:31 PM   #6
kwmech
No, same hole, but the 3/4 ton rotors are larger in diameter than the 1/2. So you need the 3/4 ton plate so the caliper will sit on the rotor in the correct place. If you use the 1/2 mounting plate the caliper will rub on the rotor.
Old 03-30-2016, 04:32 PM   #7
kwmech
No it won't
Old 03-30-2016, 04:49 PM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
I replaced the small bearing spindles on my 72 d44 with big bearing spindles from a 1977ish 1/2 ton. I used the spindles, rotor/hub assembly and caliper mount. Everything went right together. 1/2 ton 6 lug
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 03-30-2016, 05:09 PM   #9
kwmech
Yeah, my bad, I get so used to people converting from 1/2 ton to 3/4 I associated with the big bearing. Same spindle on the 1/2 and 3/4 in the later years. So yes the same 1/2 ton backing plate, either small or large spindle
Old 03-30-2016, 10:31 PM   #10
70'
70''s Avatar
Just did this myself. Big bearing spindles on D44 under 1/2 ton truck. Still using stock 1/2 ton 6 lug rotors/ Calipers/ and everything else stock but the brains and seals- they are different.
70' is offline   Reply With Quote
Old 03-31-2016, 12:53 AM   #11
kwmech
Actually the seals and outer bearings are the same. The inner bearing changes from a 603049 to 104949. Depending on the year, there may be a difference on the back of the spindle.
Old 11-25-2021, 12:25 PM   #12
ky-donzi
Sorry to revive this thread
But I have a question and I can’t seem to find a definitive answer.
Background:
I have a 73 (small bearing hub) Dana 44 1/2 ton blazer. It has the V shaped caliper mounts.
I want to replace the hub/rotor/spindle assembly with the later model big bearing hub assembly, which I see in countless places is a direct swap.
My question:
Can I use the 73 calipers and V caliper mounts with the post 77 spindle/hub/rotor? Or will I have to source different backing plates to mount the calipers?
Reid
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 11-25-2021, 03:03 PM   #13
kwmech
My question:
Reid
Yes you can as long as it all stays 6 lug.
Old 11-25-2021, 03:29 PM   #14
ky-donzi
Awesome! That makes my life easy!
Napa has new hub/rotor assemblies cheap. All I have to do is buy the plentiful large bearing spindles and new inter bearings
Thanks so much,,,happy thanksgiving!
