Old 11-28-2021, 10:02 AM   #1
Ziegelsteinfaust
QA1 control arms vs modified stick parts
QA1 offers more caster, and sounds like a great upgrade. Pricey. Well yes.
Rebuild the stock stuff about $600 with labor to press the bushing in, and installing myself. To which I could pancake the crossmember, and move the lower A arms forward. To gain caster.
Has anyone used QA1 arms after having a nicely set up stock suspension.
We're you impressed or just $1500 lighter?
Ziegelsteinfaust is offline   Reply With Quote
Old 11-28-2021, 02:18 PM   #2
pcmcobra
pcmcobra's Avatar
Re: QA1 control arms vs modified stick parts
I have the qa1 setup w/ coilovers. Night and day. Would buy them again.
Not cheap, but the ride quality is worth it.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 11-28-2021, 05:32 PM   #3
RodnRudy
RodnRudy's Avatar
I used the same setup on my 77. Like pcmcobra said money well spent.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 11-28-2021, 06:38 PM   #4
Ziegelsteinfaust
Do the QA1 arms center the A arms?
Old 11-29-2021, 02:22 PM   #5
SCOTI
SCOTI's Avatar
Are they better than the stock units?
Tubular arms are generally structurally more sound/rigid vs. stamped OE arms so that's better.
If they come loaded w/the bushings & BJ's already installed & you were already needing to spend $$ for rebuilding the OE arms, that negates some of the 'new purchase' investment expense. They're coated? That adds to the investment amount as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-29-2021, 07:30 PM   #6
Ziegelsteinfaust
But are they worth the price of admission?
Even generic arms are stronger then stamped. Except the ball joints, and don't move items around for more camber. So I can play with them.
QA1 is a great name, and have used many of there other items with great happiness. Just I have always been told, and have read. A arms alone don't make a big difference unless pick up points are moved.
Old 11-30-2021, 10:53 AM   #7
SCOTI
SCOTI's Avatar
Yes & no. Yes for some that those features are important & have value. No for others that don't stretch the limits of factory arms & can rebuild them @ a fraction of the cost.
I've yet to 'feel' my stock style a-arms flex or ever cause an issue in normal, legal driving scenarios. How will tubular arms improve an issue I don't experience?
I don't need Powder Coated parts. Nice rattle can satin black works fine & is easy to touch up. If I do get PC'd parts, they're always 'gloss' black which is NOT what I would want anyway so there's no value there for me.
Exactly what change was made to the arms for more Camber? A-arms themselves don't impact camber other than alignment. Spindle height & pivot points of the arms/BJ's impact the Camber-curve. They can alter Caster by tweaking the arms but Caster can be tweaked w/the stock arms as well. Again.... Value is subjective here.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
