Old 09-16-2017, 02:06 PM   #1
1972K20
1972K20's Avatar
Front Spring Hangers
Does anyone make these or something similar for 67-72 trucks?
1972K20 is offline   Reply With Quote
Old 09-16-2017, 02:20 PM   #2
snj8198
snj8198's Avatar
Re: Front Spring Hangers
http://diy4x.com/product.php?product...cat=250&page=1
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-16-2017, 02:58 PM   #3
1972K20
1972K20's Avatar
You have to run 52" springs with those, right?
Old 09-16-2017, 03:23 PM   #4
snj8198
snj8198's Avatar
ahh, ya i think so. I think the stockers would be too short for the rear most holes on those brackets. Not to mention, there should be a cheaper solution for you as well. Sry... I know there was a company carrying stock replacement brackets for square bodies and earlier but it's been so long I don't remember who it was.
Steve
Old 09-18-2017, 09:22 AM   #5
Joesjunk
Joesjunk's Avatar
These were just posted
http://67-72chevytrucks.com/vboard/s...d.php?t=746811
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-18-2017, 11:27 AM   #6
1972K20
1972K20's Avatar
Thank you
Old 01-22-2018, 07:06 PM   #7
sdcarsey
I'm needing a set also, may have to do the 52" set-up...is that what the squarebodys had was 52" springs? Just wondering how much more cash I'll have to shell out if I go that route. I bought a truck that has been put in a ditch on passenger side and twisted and tore the front passenger spring hanger.
sdcarsey is offline   Reply With Quote
Old 01-22-2018, 07:15 PM   #8
b454rat
I don't think you "have" to run 52s with that kit, I wanna say using stock 47s will move the axle forward 1". I had a set of these on a 2wd crew that I converted to 4wd, and used stock style 4" 47s. You don't have to do much just to run 52s. Mainly moving the front mount forward.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 01-23-2018, 02:52 AM   #9
'63GENIII
'63GENIII's Avatar
IIRC, the front eye mount is right below the radiator core mount. The set I have ('67 - '72) has a mess of holes all over it. I wouldn't be a bit surprised if there were eye mounts for the stock location that would let you run the 47s. I can take a look tomorrow and post back. The B52s are a bulletproof set that belong on a battleship more than a truck.
FWIW, 52s aren't a big deal to install either.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 01-29-2018, 03:37 PM   #10
Benjamin
Benjamin's Avatar
subscribing
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels
1976 K20 crew cab, 350/Ranger/SM465/NP205
Benjamin is offline   Reply With Quote
Old 11-30-2021, 11:38 AM   #11
Ford Assassin
Ford Assassin's Avatar
Digging up an old thread....
Originally Posted by snj8198 View Post
The trouble with those, looks like you can use stock front bumper brackets anymore....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-01-2021, 05:30 AM   #12
Richard
Do not believe the B52 brackets interfere with the bumper. Side braces will bolt up just like stock in the radiator support section. May be able to use the longer 73+ front springs with the brackets for a stock like height. Think it was mentioned the furthest back bolt location is about 1" froward from stock.
52" never came on the front of Chevy 4x4's. Off the shelf you will have to use rear springs. They will have more arch and will add 4"-5" of lift with the kit. If you want lower custom springs are the only option with the brackets
Richard
Old 12-02-2021, 12:59 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
They actually won't let the bumper go on. You'd have to cut/notch the bumper to get it to bolt on correctly. I put a pair on a 72 I was K swapping and I ended up pulling them off and installing oem ones because of this.
Ryan
1969 Chevy milk truck
Old 12-02-2021, 01:07 PM   #14
Ford Assassin
Gotcha.
Looks like I might go with Sky's Drop Perch instead.
Cable
Old 12-02-2021, 01:12 PM   #15
Dieselwrencher
If you weren't putting the spring in the front hole, you could cut the DIY perch and leave the bumper alone. I needed the front hole to make it all work so I just started over with Alcan springs.
Ryan
Old 12-03-2021, 01:59 AM   #16
Richard
Interesting information. I purchased a set of the b-52's but ended up going a completly different direction with the front suspension. I have never heard of interference issues. Any possibility the C to K swap may have something to do with it?
Richard
Old 12-03-2021, 06:33 AM   #17
Dieselwrencher
I wondered the same thing. I'm going to make a template from a K frame horn and place it over the C frame horn so I can add the tow hook holes. We'll see then how much horn difference there is. This frame is a Longhorn which is a 1 ton based frame, and I'm betting it's different than a C/10/20.
Ryan
