Old 12-05-2021, 09:13 AM   #1
bestchevyfan
Swapping gauge insert
My 1987 truck has idiot lites and i want to change to gauges with a clock. What do i need to do ??
bestchevyfan is offline   Reply With Quote
Old 12-05-2021, 07:42 PM   #2
Nick_R_23
Nick_R_23's Avatar
Re: Swapping gauge insert
You’re in for some wiring. You’ll need to replace the oil pressure and temp switches with sending units, the under dash and engine bay wiring is different, and the entire gauge cluster will need to be changed.
Nick_R_23 is online now   Reply With Quote
Old 12-05-2021, 08:34 PM   #3
evan
evan's Avatar
That's not what I was hoping to hear. I found a set of gauges to replace my idiot light gauges and was hoping it would be simpler.
Evan B.
evan is offline   Reply With Quote
Old 12-06-2021, 09:49 AM   #4
TrailerTrash
TrailerTrash's Avatar
It is not simple at all. I am sure many of us had the same idea at one point or another but there is a good bit to it as said above.
The idiot lights arent individual cups that can be removed to make room for small guages. It's all one large assembly that houses all the gauges or gauges+idiot lights. You would have to cut stuff up to make room then run all your own wiring for new gauges then mount everything and make it look good.
Not trying to scare you away from the project, but it wouldnt be easy
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 12-06-2021, 11:30 AM   #5
evan
evan's Avatar
Just to clarify, I was talking about swapping a stock gauge cluster that has needle gauges in place of the stock gauge cluster that has idiot lights. Is that what you're talking about?
Evan B.
Old 12-06-2021, 04:50 PM   #6
Nick_R_23
Nick_R_23's Avatar
Yes. The gauge cluster itself (housing, lens, circuit board) is different between the two versions, the entire unit needs to be replaced. Along with the interior and engine bay harnesses, although it’s not impossible to rewire them for the gauge style clusters. Lastly, the actual sensors on the engine for the gauges are different - idiot lights used switches (on/off at a certain spec), and gauges used sending units. The sending units should physically fit where the switches were, but the connectors and wiring is usually different.
It’s definitely not impossible, but it will take a little effort and ability to compare wiring differences between both styles.
Old 12-07-2021, 10:52 AM   #7
blazer2007
If you don,t want it factory wiring I used the idiot light curcuit board and just wired the temp and oil gauges seperate to gauge sending units my clock didn,t work so I never did that wiring but left the clock in anyway. If you want to re-pin the the harness I think this the thread. http://67-72chevytrucks.com/vboard/s...d.php?t=452340
blazer2007 is offline   Reply With Quote
Old 12-07-2021, 01:30 PM   #8
wazzabie
I thought the gauge clusters clusters were swappable with dependency upon certain years. Maybe that is only if you are adding a tach cluster to an existing gauge cluster with no tach. I have a 78 gauge cluster that I'm swaping to a tach cluster. Other then adding the tach wire I've been told it is plug and play.
wazzabie is offline   Reply With Quote
Old 12-07-2021, 07:46 PM   #9
hatzie
Moderator
hatzie's Avatar
It's not oogie boogie. It's also not difficult.
You can swap 1973-80 warning lamp clusters for 1978-80 gauge clusters with some minimal work. Don't use the 73-77 clusters for this.
1973-75 gauge clusters have ammeters and capillary tube oil pressure gauges.
The ammeter was replaced with a Volt gauge in 1976.
The capillary tube gauge was superceded by an electric gauge in mid 1977.
The gauge fonts and colors changed in 1981.
The wiring from the engine bay will work for gauge senders or lamp switches.
The instrument panel plug will need to be re-pinned.
The temp and oil pressure switches will need to be replaced with gauge senders.
Pinout charts are in this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=456877
Year specific GM wiring diagrams are in the manuals thread in my signature.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-07-2021, 08:24 PM   #10
wazzabie
Is there any advantage to use the capillary tube gauge vs the electric temp gauge?
Old 12-07-2021, 10:25 PM   #11
evan
evan's Avatar
That's very helpful. Thanks.
Evan B.
Old 12-08-2021, 05:17 PM   #12
hatzie
Moderator
hatzie's Avatar
It's the oil pressure gauge that uses a copper capillary tube with compression fittings on the engine and the gauge.
The temp gauge was always electric. The temp sender was a nailhead thermistor sender through 1979 1980ish and then various flavors of thermistor senders with differing resistance curves. The less than pleasant reality is that the replacement nailhead senders and probably the others have a different thermistor semiconductor brew than the originals so I'd keep your old ones as long as they work.
IMHO the negatives of the old oil pressure gauge outweigh the positive.
Old 12-18-2021, 11:56 AM   #13
bestchevyfan
To change it out === i will need a dash cluster w/ gauges == i have it . [2] wiring harness for under dash. [3] wiring harness for under hood [engine] [4] send units for under hood . Is this all i will need ??????? Thanks,buddy
Old 12-18-2021, 07:06 PM   #14
TKCR
TKCR's Avatar
You sure are a big asset to this board! Your knowledge & help is greatly appreciated.
Old 12-19-2021, 07:19 PM   #15
Factory Guy
Factory Guy's Avatar
American Autowire has the dash gauge harness you might be in need of
https://www.americanautowire.com/sho...harness-105011
Factory Guy is offline   Reply With Quote
