03-02-2021, 11:57 PM | #1 |
Vintage air heater control valve placement
Any ideas on where to hide the heater control valve? Can you put underneath the dash in the lines?
OLDIRONRACING |
12-05-2021, 09:35 PM | #2 |
Re: Vintage air heater control valve placement
I ran my heater lines along the top of the inner fender well behind where you put the fender bolts in. So I went ahead and mounted it where you wouldn't see it under the fender.
It really doesn't matter where you put it since it is just a valve. The intent is to cut off coolant flow so that the A/C doesn't have to work as hard to cool the cab.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
12-05-2021, 09:50 PM | #3 |
Be carefull in mounting. I found out its driectional when I had heating problems.
