Old 12-05-2021, 08:48 AM   #1
65truckowner
65truckowner's Avatar
one inch drop coils
I have a set of 1 inch drop coils in the front of my 65 c10. I now have the engine installed and most of the front clip and the springs hardly moved at all If I stand on the frame and bounce it they seem really stiff. Will they settle at all once I start driving it? I was planning on installing 3 inch drop in the rear but am afraid the rear will be lower than the front
65truckowner is offline   Reply With Quote
Old 12-05-2021, 01:52 PM   #2
SkinnyG
SkinnyG's Avatar
Re: one inch drop coils
Drive it a bit and let it settle (if it settles at all), then trim a bit of the front coil spring bit by bit until you get the stance you want. I usually cut the last inch or two off the end of the pigtail.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-05-2021, 07:27 PM   #3
65truckowner
Ok thanks
Old 12-05-2021, 08:32 PM   #4
VictoriaHardware
VictoriaHardware's Avatar
Most aftermarket spring suppliers sell you a "X Inch Drop" spring. They are guessing since they know nothing about your specific truck. Like if you have a 230 L6/ 3 Spd or an iron 454 V8/Turbo 400. Also they are not able to tell you what the spring rate is. Spring length and spring rate are two entirely different things. Always remember if you shorten a given spring, you are increasing the spring rate.
VictoriaHardware is offline   Reply With Quote
Old 12-05-2021, 09:40 PM   #5
grubsster
grubsster's Avatar
Here's mine. I did 3" in the back and 1"in the front. The first pic is without modifying the front springs. The second is after I cut about half of the first coil off the front springs. I think it actually lowered the front about 2". Gave the truck a really good look I thought. All the springs were purchased from CPP.
Also the first picture had the 250 6 cylinder 3 speed and the second was with a 283 th350 automatic. I think the 250 is actually heavier but not sure. Hope that all makes sense...
grubsster is offline   Reply With Quote
Old 12-05-2021, 09:50 PM   #6
SkinnyG
SkinnyG's Avatar
I buy MOOG 1-ton coils, and just keep lopping inches at a time until it sits perfect.
Old 12-06-2021, 12:56 PM   #7
Chevy Fleetside
Chevy Fleetside's Avatar
3in drop spindles and 3in drop springs. Might look funny since the truck is facing up hill and not on flat land.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
