Old 07-21-2004, 06:49 PM   #1
Tom
driving is in my blood
Tom's Avatar
part throttle stumble?
My engine has a stumble under part throttle when it gets hot around here and I can't tell why. Its been tuned correctly and the plugs look good, also my a/f gauge says the ratio is good.
The only time it acts up is when going from a stop and you just get on the gas, it stumbles. Once your going theres no problem, and if you start from a stop and give it a good amount of pedal then theres no problem. Any ideas?
Old 07-21-2004, 08:55 PM   #2
MSL
MSL's Avatar
what kind of carb do you have.
MSL is offline   Reply With Quote
Old 07-21-2004, 10:25 PM   #3
Tom
Tom's Avatar
Its a carter 600cfm with no choke. It has a HEI with 14* initial hooked up to ported vaccum.
Old 07-22-2004, 01:07 PM   #4
PHOENIX
Tom, are you running an egr on that engine?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 07-22-2004, 03:32 PM   #5
Tom
Tom's Avatar
no egr
