Old 12-08-2021, 12:19 PM   #3
edgeleycanuck
Re: 54 Door Window Track Felt
Originally Posted by joedoh View Post
i used to use precision, but now its too tight in the channel and that means tight on the glass. i switched to lmc but this year they switched suppliers (and dont really care about complaints) so I think from now on I will just buy Steele rubber kits, they are seriously like $200 more but for $200 less you can get stuff that doesnt work I guess.
https://www.steelerubber.com/side-wi...kit-70-2485-58
there is the window track kits, for a complete set you will also need the $132 wing window stuff.
https://www.steelerubber.com/front-d...set-60-0065-55
thats for 51-55 with wing windows!
Question regarding the rivets in the vent window upright channel. Russ do you use the original style rivets with the Steele product (or others)? Or have you developed an alternative solution? I've read the original rivets can be awkward to replace especially the vent window pivot rivet.
edgeleycanuck is offline   Reply With Quote
