![]() ![]() Join Date: Jan 2005
WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I've currently got a two-piece two-groove crank pulley setup, and I'm looking to go to three grooves so I can add A/C. I believe I only need a new inner pulley with two grooves to go with my current outer single-groove piece. Please correct me if I'm wrong.
![]() Join Date: Mar 2010
Re: WTB - 3 Groove Crank Pulley for SBC with Short Water Pump
I hope this helps. The part number is 3744043 this is the 2 groove pulley. Still can be purchased thru GM. Can also be purchased on EBay. If you need more help let me know I have this pulley setup on my 72 with factory air. Thanks Don
Thank you! I'll order a new one.
The other pulley #3751232 would be the power steering pulley single groove. That should you there. Don
Do you think my existing single groove crank pulley for my PS will work with the double groove pulley?
#6 | |
Always on the hunt...
![]() Join Date: Sep 2006
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
I'm planning on installing a Vintage Air system on my non-A/C 1968 truck. Based on what I've read on their website, my understanding is that OEM A/C pulleys should line up with their aftermarket compressor that mounts on the passenger side of the engine. I have the original non-A/C pulleys on my truck currently, along with power steering. I have purchased a two groove water pump pulley, but I will need to check the part number to verify it is the same as the one you posted. I will take you up on your offer for the OE two-groove crank pulley, but let me check the part number of my water pump pulley in case I need that too. I am out of town right now so I won't be able to check until later this week. Thank you for your help!
#8 | |
3744043 BA Crank Inner Two Groove Pulley 3995646 AH Water Pump Two Groove Pulley |
#9 | |
#11 | |
Do either of the pulleys have pitting from rust, or is there only surface rust?
![]() Join Date: Jun 2019
What part number is the other crank pulley
#14 | |
#15 |
Surface rust is just fine. I bought another pulley recently, and it ended up having serious pitting, so I just don't want to repeat that mistake. I'll send payment shortly.
#16 |
Payment sent
#17 |
If asking for 72 small block applications, the other stack/add on single groove outer crank pulley for driving the p/s pump would be p/n 3751232 BB and the matching single groove pulley on the p/s pump would be p/n 3993325 DJ. Here are a few pics of a complete OE power steering changeover removed from a 72 2wd S/B 350 truck showing the matching p/s pump mounting brackets along with both of the mentioned 232 BB and 325 DJ pulleys. Mel
#18 |
![]() Join Date: Mar 2018
Is this also the correct parts for a 68 w/ps and factory air? Short water pump.
#19 | |
#20 |
The pair of pulleys are headed your way, the package went out via USPS priority on Mon. 11/22 and the expected delivery day is this Wed. 11/24. Thanks again for the repeat business and let me know if we can help with any other 67-72 parts needs, Mel
#21 |
Thank you!
#22 |
The pulleys arrived safely. Thank you for your help.
-Patrick |
#23 |
![]() Join Date: Feb 2005
I also am looking for a double groove crank pulley as well as a 3993325 p/s pump pulley
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
#24 | |
#25 |
Great thanks!
