Old 12-10-2021, 05:00 PM   #1
68Stepbed
68Stepbed's Avatar
Meaty!!
I finally got some tires that start with 3!! Got my new 18x11 Rocket Attack wheels put on with 315/30/18 tires!! To get the backspacing I wanted, I had to convert to 5x4.75 bolt pattern. The front was easy with the Wilwood setup since they're already drilled and tapped for both with screw in studs. For the rear, I swapped in a new set of Moser axles, then used a drill guide from Hells Gate Hot Rods to drill the rotors.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-10-2021, 05:41 PM   #2
Joyridin
Re: Meaty!!
Looks great!
Joyridin is offline   Reply With Quote
Old 12-10-2021, 06:56 PM   #3
Boog
laying low
Boog's Avatar
Re: Meaty!!
That's a lot of rubber under there Matt. I like it!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 12-11-2021, 12:52 PM   #4
Re: Meaty!!
I can't believe you found a way to improve on that truck. But you sure do manage to do that well. That is one fine purpose-built '68!
Old 12-15-2021, 10:32 AM   #5
68Stepbed
68Stepbed's Avatar
Re: Meaty!!
Thanks, guys!!
Tim, you know I'm always gonna make some cool upgrades! I've got a big upgrade coming sometime in 2022!!!!
Matt
Old 12-15-2021, 03:26 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Re: Meaty!!
Meaty beaty big and bouncy
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-15-2021, 10:45 PM   #7
dagnabbitt
dagnabbitt's Avatar
Re: Meaty!!
Looks amazing, congratulations. Those wheels really suit the truck.
I know how much time and measurements go into wheel selection, it is sure nice to see it pay off like this.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-16-2021, 11:57 AM   #8
OregonNed
OregonNed's Avatar
Re: Meaty!!
looks awesome!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 12-16-2021, 04:58 PM   #9
basketcase
basketcase's Avatar
Re: Meaty!!
Looks great.
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 12-16-2021, 08:36 PM   #10
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Meaty!!
Could I ask what back space you have? Trying to do the same thing with my 20s
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-17-2021, 07:04 PM   #11
Re: Meaty!!
I wanna ride!
Old 12-17-2021, 10:38 PM   #12
LS short box
Re: Meaty!!
I bet it's not very good in snow!
Just kidding looks great.
Old 12-17-2021, 11:13 PM   #13
Mike C
Mike C's Avatar
Re: Meaty!!
How did you handle the inner bedsides? I know you were running 285 compared to my 275, but there ain’t no way anything that starts with a 3 fits underneath with stock inners!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-19-2021, 02:47 PM   #14
Hotcorner
Hotcorner's Avatar
Re: Meaty!!
That’s a badass truck. Where in TN?
1969 GMC K25
2007 Chevy 2500HD Classic Duramax
1999 Tahoe 2DR 4WD Base Model 5.7l
Hotcorner is offline   Reply With Quote
Old 12-21-2021, 12:34 PM   #15
68Stepbed
68Stepbed's Avatar
Re: Meaty!!
These are 6.5" backspace. Keep in mind, you'll still have to measure and make sure what size you need. Your suspension may not allow for the same clearance that my TCI stuff does.
I tubbed her a couple years ago.
Down the road in Sevierville.
Matt
Old 12-21-2021, 09:38 PM   #16
Re: Meaty!!
I like that SCCA sticker on a pick'um up... and it belongs
Old 12-22-2021, 12:23 AM   #17
Mike C
Mike C's Avatar
Re: Meaty!!
Awesome. My original bed floor has finally failed. Maybe I will do some mini-tubs like that as well. The big tires look sweet!
44 Willys MB
52 M38A1
64 Corvette Coupe
