Old 12-12-2021, 04:21 PM   #1
71mr.musturd
lowering advice, tips, packages for my 70 c10
I'm looking to lower my 1970 c10. I'd like to just use drop springs for now. How low can/should I go with just doing drop springs. Would love to hear what packages you guys suggest and any pics of what my ride height will coming out looking like. Thank you
Just a 25yr old trying to learn
71mr.musturd is offline   Reply With Quote
Old 12-12-2021, 05:28 PM   #2
davischevy
davischevy's Avatar
Re: lowering advice, tips, packages for my 70 c10
This truck has 2 inch dropped spindles and 1" springs in the front with 5" dropped springs, shock relocators and adjustable panhard bar in the rear. It rides great.
I you try to do 3" in the front with springs, you will sacrifice ride quality.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 12-13-2021, 02:01 PM   #3
jimijam00
Mos def get shock relocation brackets. You don't want your rear shocks laying at a 35-40 degree angle, but much closer to 90 degrees. Maybe a panhard bar relocation too. Get the No-Limit stuff.
jimijam00 is offline   Reply With Quote
Old 12-13-2021, 02:48 PM   #4
geunther
geunther's Avatar
Originally Posted by jimijam00 View Post
Most def get shock relocation brackets.
Hijack apology but might be helpful to the OP as well.
Anyone know of the rear shock relocating brackets that use existing holes and do not require the removal of rivets?
geunther is offline   Reply With Quote
Old 12-13-2021, 04:55 PM   #5
jimijam00
The ones I posted above do not require removal of rivets. They do require a cobalt bit to drill through the frame. I highly recommend new ubolts too.
Old 12-13-2021, 10:36 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I have a set of 2 1/2 inch drop spindles and 4 inch rear drop springs with an adjustable panhard bar and rear shock relocators ready to go on my truck in Spring. Just put the 255/60 17 TT2's on in August and just want the slighty lowered look for the truck. The 17's andtires are only .18 inches higher than the 235/75 15's that have been on my truck since I bought it.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-13-2021, 10:40 PM   #7
LagunaGlide
This is the route I a going as well. I have already ordered some parts, but waiting is half the game these days.
Truck looks good. What size tires you running?
OP the 3 front, 5 rear is pretty standard with minimal changes. If you want just springs I have seen some spring kits that are 2" front and 4" rear.
LagunaGlide is offline   Reply With Quote
Old 12-13-2021, 11:28 PM   #8
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
This is the same way I went before going with coil overs. Some need a C Notch some not. The adjustable pan hard is a must also
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 12-13-2021, 11:34 PM   #9
kaycee
kaycee's Avatar
I did a 2.5" front cut spring (1 ring) on the front and Jeep TJ springs in the back for 4 " of drop . Search on this forum and you can find the home made shock relocators for front and back not hard to fab. My truck rides like a dream and will haul a decent load allso but I dont use it for that a cruiser street brawler mostly.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-14-2021, 02:32 PM   #10
SCOTI
SCOTI's Avatar
Nice looking truck.
Is it still stock drum brakes or have disc brakes been swapped?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-14-2021, 04:40 PM   #11
72kat
Dig the wheels. what are they?
72kat is offline   Reply With Quote
