Old 12-15-2021, 01:08 PM   #1
Ford Assassin
Ford Assassin's Avatar
Re: Anyone Running FRONT Radius Arms?
Originally Posted by Richard View Post
A radius arm axle tends to have a more torsion bar type action as opposed to a four link which will be looser on the articulation movement. The radius arm setup also changes pinion angle and caster quite a bit more through travel over the 4 link. On the 4 link pinion angle and caster remains fairly constant. Was looking at radius arm from Blitzkrieg as well as 4 link by ORD. I chose the four link over the radius arm myself. Am running a sway bar as well which is added cost.
I appreciate the response.
The reason the radius arm setup attracts my attention is the simple nature of it.
Plus I am NOT gonna do any real off roading
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 12-15-2021, 01:47 PM   #2
Willowrun
Willowrun's Avatar
I have some Fords with the factory radius arm front suspension and based on how they ride (nice) and the fact you will be using it primarily on the road I would go radius arms all the way. Panhard needs to be parallel with steering arm and caster at 5% or so and you’re good.
Old 12-16-2021, 04:09 AM   #3
Richard
Radius arms will most likely work for you and would have been fine for me. Maybe even without a sway bar. The 4 link was probably more fab work but that is mostly just time for me. I have a higher lift height and wanted to keep link bars or arms flatter. They have to be longer to achieve that. Four link kit allowed for custom length. Flatter bars equal a better ride and road manners. Final deciding factor for me was the radius arm kit I was looking at would have ended up costing more money in the end.
Richard
