![]() Join Date: Feb 2009
NP 205 shift lever question
Does anyone know if a 205 shift lever from a 71/72 is the same for 73 and newer?
All about them K’s
![]() Join Date: Jun 2014
Re: NP 205 shift lever question
No they quite different aside from mounting to the transfer case.
Top is 73-87 Bottom is 71-72 Edit: I need sleep. Bottom is actually my 70 only SM465 NP205 shifter.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 12-12-2021 at 08:09 PM. |
6>8 Plugless........
![]() Join Date: Sep 2007
Tyler, isn't your bottom pic 69/70 np205 only?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
All about them K’s
Lol good catch, the two pictures I’ve got in my phone of 70 and 71-72 were right next to each other. That’s what I get for not proof reading. Here’s one I took that illustrates 70 only vs. 71-72, so you can compare them both to 73-87. Black is 71-72 and the bare metal is 70.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Does this look like 71/72?
All about them K’s
It could be, the 71-72 doesn’t bend as far to the center of the truck as the 70 only does and the square body shifters I’ve seen/had don’t look the same at the bottom where they bolt up to the transfer case adaptor. Notice how the square body piece I posted earlier is welded down by the bolt hole.
#7 | |
All about them K’s
I would see if you can get a picture of the top half of the shifter. That will tell the whole tale.
All I have
All about them K’s
That’s not a 71-72, look at how it’s straight coming thru the floor, all the way to the top of the shifter. The black one in the picture I posted is not completely straight.
like pics show, the 73 and newer shift levers come up straight through the floor, the 71-72 levers are longer and have a bend in them, they bend towards the seat, levers do interchange,you can put a 71-72 lever on a newer 205
All about them K’s
Correct, levers interchange, holes on the floor do not in most cases though.
Thanks for all the replies, I was able to buy an original chrome 72 shifter today.
All about them K’s
Awesome. Just for future reference here’s a picture I took today of my collection of different handles. This should clear up the differences, also I took a picture of one of my 71-72s mounted to a case.
Left to right 70 only 205/SM465, 73-87, 71-72
#15 | |
Scott |
#16 |
I bought one of the 73-87 shifters you show a picture of to put in my ‘86 K30 and it is completely different from the OEM ‘86 shifter which comes up much lower and bends towards the driver like your ‘70 only shifter. The longer, straight up shifter would not fit through the hole in my ‘86 so I just kept the shorter shifter.
#17 |
![]() Join Date: Oct 2016
This thread has been educational. I had no idea there were different variations of the 205 handle.
I have a SM465/NP205 I'm planning on putting in my '68 K10. Appears to have the squarebody shifter handle. Obviously not going to work with the hole for the rockwell that's in it now. Do you guys think I should just get a new hump and cut holes to match the squarebody arrangement? I really hadn't even considered it until I saw this thread. |
#18 | ||
All about them K’s
I would buy a 71-72 4 speed/4x4 high hump and a 71-72 shifter from the parts board if it was me. No cutting required this way. Quote:
That truck didn’t have a removable high hump like a lot of the earlier squares I’ve messed with. My 69 K10 had a 205/465 swapped in it with the same shifter from an unknown year square body.
| Bookmarks |
