3 or 4 row
Hey All,
Question its time to replace the radiator in my 70 cst 10 . I have repaired it all I can, the tubes are getting really thin. My question is, I have been seeing options for a 3 row or 4 row W/ A/C, and yes i have A/C and the old radiator is a 4 row. NOW before everyone starts dog piling on me I understand the whole the thicker the coil the more efficient, but my question is was there a option for a 3 or 4 row coil on a 70 cst. Just wondering why I am given the option between the 2. Just thinking if I don't need a 4 row why get a 4 row, has anyone gone from a 4 to a 3 row? Thanks. |
![]() Join Date: Dec 1999
Re: 3 or 4 row
Why not have yours recored?
Smitty '71 Short Fleetside Spring Valley, Ca. |
![]() Join Date: Mar 2003
Re: 3 or 4 row
upper and lower mounting pockets will be different
Re: 3 or 4 row
I would rather have the 4 row. If you have more radiator than you need, the thermostat regulates it and if you dont have enough radiator, you get to sit along the road waiting for it to cool off.
Senior Moment
![]() Join Date: Mar 2002
Re: 3 or 4 row
I’m the 2nd owner of my 70 CST and it had and still has a 4 core Rad. It’s been though my SB, BB and now my LS. It’s been cleaned up and modified a couple of times. If it ever gets to the point of a recore, that’s what I’ll do. I imagine it was a 4 core because of factory air, as mine is
Just My 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Re: 3 or 4 row
My vote is for option three. Two core tripple pass.
Re: 3 or 4 row
Re: 3 or 4 row
#9 | |
Re: 3 or 4 row
Morepwr, I get it, I was just wondering if this was a option when you ordered the truck, maybe a upgrade back then from a 3 row to a 4 row. |
#10 | |
Re: 3 or 4 row
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: 3 or 4 row
Well, I am no help at all but here's my two cents. My '72 K20 has factory air. I replaced the original radiator many years ago and scrapped it. Don't remember what it was, probably a 3-row, but I know for sure it was not a 4-row. I replaced that old rad with a new 4-row copper/brass unit that's still working great after fixing some small leaks a few years back.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
![]() Join Date: Feb 2016
Re: 3 or 4 row
There only 2 tank sizes from the factory. Referred to as the 2 row and the 4 row. I've never seen any factory documentation that states how many rows each radiator option had.
I do know that there are some differences in the factory transmission cooler sizes inside the tanks. As far as recoring the radiator there are different types available today and a 3 core designed to fit the 4 core tanks is available. There are plenty of cheaper options than a true GM factory style core. The best factory style cores are made in Canada presently. I would inquire at your radiator shop about the different cores available for your tanks and what the differences are. If they don't know about any differences go somewhere else. My factory style 4 core with the large plate style transmission cooler was $700 back in April 2018. It came with a 5 year warranty. My Burban is a daily driver and I do tow occasionally with it so for me the piece of mind was well worth the cost. Ultimately what size you choose will be a balance between budget and your driving needs. If your current radiator is keeping the engine cool why downsize? If you're okay with having to modify the mounts and shroud pickup a low cost roundy round aluminum radiator you can save some money upfront but, be aware aluminum radiator cores aren't really repairable. Covering holes with epoxy is all you can do. Where as copper can be soldered for a permanent repair. By today's standards GM had under sized radiators and fans back in the day. They were never expected to encounter stop and go traffic. Happy shopping!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
20' Daredevil (Ret)
Re: 3 or 4 row
That being the case, my original (mentioned above) must have been a 2-row. All I remember is it was awfully skinny.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 3 or 4 row
I have a 72 C10 with a 350 and Factory A/C and it has its original 3 core rad and I thought it should/would have the 4 Core cause of the A/C. Looking at it it has the same tanks as a 4 core rad. Engine and rad recently pulled from my truck as putting in another small block in a few months. I've been going back and forth for a year or two now whether to get an aftermarket brass/copper rad or get mine recored into a 4 core. Timely thread for me as I'm taking the rad to the local, been in business for 100 years, rad shop for a quote and options for the rad. I took the original heater core from my 76 Dodge pickup there last year as core was shot and they had bulk cores there and cut a piece to fit the core and works perfect. I will keep you posted as to what they say. I do expect to be paying more for a recore than an aftermarket brass/copper rad but trying to keep truck as original as I can.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#15 |
![]() Join Date: Jul 2015
Re: 3 or 4 row
I'd go with a big tube aluminum radiator from ECP ( engineering cooling products) . They have one for non A/C and one which is wider for the A/C trucks. It will cool alot better.
#16 | |
Re: 3 or 4 row
#17 |
Re: 3 or 4 row
If I am understanding correctly, a 3 core will fit both the 4 core tanks and the 2 core tanks? The reason I ask is my truck originally had a 2 core. When I had it done a month ago he cored it to 3 for me with the original tanks.
Just curious. |
#18 |
Re: 3 or 4 row
Actually getting mine done as a 2 core was an option too but more costly than the 3 or 4 core.
#19 |
Re: 3 or 4 row
Rows. It's rows, not cores.
#20 |
Re: 3 or 4 row
Your right but knew what I meant lol
#21 |
Re: 3 or 4 row
For real.
#22 | |
Re: 3 or 4 row
Things were much more cut and dry back in the day.
#23 |
Re: 3 or 4 row
I went with a 3 row/core. Engine that previously ran hot in summer with a/c on at idle went to temp gauge sitting in middle or occasionally just to the right of center.
Now with my LS 5.3L swap, the gauge sits well to left of center. I did have to section my top brackets. |
