Old 12-17-2021, 08:20 AM   #1
BrentBTK
Leaf Spring Lowering Brackets too wide
This truck has been fighting me every step of they way with this suspension. I just moved to the rear yesterday afternoon, and when I went to install the lowering brackets for the leaf springs, they were significantly wider than the perch they sit in. Attached is a photo showing the difference in the center pin on the old bracket vs the new one. Has anyone else had this? The DS2 rear shocks Western Chassis sent were the same way. I had to grind down the pins and the bushings to get everything to fit between the brackets. SSybil is living up to her name, lol.
BrentBTK is offline   Reply With Quote
Old 12-17-2021, 04:52 PM   #2
SCOTI
SCOTI's Avatar
Re: Leaf Spring Lowering Brackets too wide
What year truck are you working with?
What specific "lowering brackets" for the leaf springs are you referring to?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-17-2021, 11:04 PM   #3
Mike C
Mike C's Avatar
69-72 2x4 trucks except Longhorns have 2 1/4” wide leaf springs, Longhorns, 4x4’s and square body trucks have 2 1/2” wide springs. OBS or GMT-800 and GMT-900 trucks I have no idea.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-18-2021, 08:27 AM   #4
BrentBTK
Interesting. It's a '71 GMC. SPID below. Says "Heavy rear springs" I purchased a kit from Western Chassis that included new coils and spindles up front and drop brackets and 4" drop leaves for the rear. The springs themselves are on backorder until February. It was only the base of the brackets that was too wide. (The part that bolts into the pocket on the frame) The top of the brackets where the spring attached is perfect. I had to trim about 1/4" off the pins and sand the bushings down to fit. Same thing with the rear shock bases. I called them while I was in the middle of it, and they had never heard of such a thing... shocking, lol.
Old 12-20-2021, 12:48 AM   #5
Mike C
Mike C's Avatar
My ‘69 short step has the heavy rear springs. They have an additional leaf.
44 Willys MB
52 M38A1
64 Corvette Coupe
