Old 12-21-2021, 08:47 AM   #1
03BlkZ
3 speed RPM question
Hello, I finished my resto on my 70 C10 about 10 months ago and now I have a question about RPM. My truck didn't have a factory tach and I didn't add one during the resto but now I wish I would have. My truck is a 350 with 3 on the tree and 3.73 gears. I am running a 255/70/15 tire. When going 60 to 70 mph it sounds like I am running a pretty high RPM. Anyone here have a tach with the same setup as me that can tell me what RPMs you are running?
03BlkZ is offline   Reply With Quote
Old 12-21-2021, 09:47 AM   #2
geezer#99
geezer#99's Avatar
Re: 3 speed RPM question
At 70 it’ll be spinning about 3000 rpm.
Use this calculator.
http://www.advanced-ev.com/Calculators/TireSize/
geezer#99 is online now   Reply With Quote
Old 12-21-2021, 12:16 PM   #3
kwmech
What do you have for a fan?
Old 12-21-2021, 01:27 PM   #4
Accelo
Accelo's Avatar
Good point on the fan. A none OEM fan can add a lot of noise.
As we all have become accustomed to modern cars the typical motor RPM of vehicles the old cars and trucks, without overdrive transmissions, seem noisy because they are. If you had installed a modern automatic with overdrive installed the motor rpm would be closer to 2100 rpm. The early motor speeds seem ridiculous now days. You could change the differential or look for a stock three speed with overdrive for your truck. Frankly I am a little surprised there weren't more of these ordered back when. I did add an automatic overdrive transmission to a 1971 3/4T 396 truck I had. Increased the highway millage from 10 to 13mpg. a 33% improvement with no other changes. It quieted down the interior of the truck immensely.
BTW you would have to have a 2:61 rear end ratio to get the motor rpm down to 2100rpm with the transmission you have. It would be impossible to get moving on a hill. Yes, the overdrive is one of the best upgrades you can do in our old vehicles to make drive better and quieter.
Accelo is offline   Reply With Quote
Old 12-21-2021, 06:09 PM   #5
03BlkZ
I have the stock clutchless fan.
Old 12-21-2021, 06:33 PM   #6
kwmech
Hard blade or flex?
Old 12-21-2021, 09:25 PM   #7
03BlkZ
Hard blade or flex?
I assume hard.
Old 12-21-2021, 09:34 PM   #8
Why no clutch? They are meant to be and worth having, too. You don't even need a fan most of the time. Also, you know the revs have nothing to do with having a 3spd, right. It's all the same, 1:1 final drive unless you have overdrive
Old 12-21-2021, 10:28 PM   #9
70STOVEBOLT
70STOVEBOLT's Avatar
I have a 70 with a 402 and TH400 with 3.73 gears, also running 255/70-15s and my tach reads about 2500-2600 at 60 mph. The engine doesn’t matter much, the RPM should be the same as your 350, given the same final drive ratio and tire size.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-21-2021, 10:39 PM   #10
jocko
jocko's Avatar
Geezer and 70Stovebolt are spot on.
Exact numbers by the math for your transmission final drive (1:1), rear end (3.73), and tire dia (29.1" for 255/70/15) combo:
50 mph=2153 RPM
60 mph=2584 RPM
70 mph=3015 RPM
Old 12-21-2021, 11:38 PM   #11
03BlkZ
Thank you all. It's just hard to get used too the higher RPM. I am used to rolling 80 at about 1800 rpm in my Z06.
Old 12-22-2021, 12:41 AM   #12
geezer#99
geezer#99's Avatar
You want to try 4200 rpm for 240 miles in a 56 gmc with an L-88 427.
That’ll get you buzzed for awhile!
Old 12-22-2021, 11:58 PM   #13
AJC
Here is an approximate engine RPM depending on speed.
I may have got the 3 speed gear ratios wrong; I can update it if I did.
AJC
AJC is offline   Reply With Quote
