Old 12-21-2021, 10:46 PM   #1
Afirehawk1
66 C10 Stepside Remote Fill Ideas Wanted
I have my Boyd tank installed in the rear
I dont want to come up through the bed floor
Any ideas installing the fill on the bed fender??
Afirehawk1 is offline   Reply With Quote
Old 12-21-2021, 10:56 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 66 C10 Stepside Remote Fill Ideas Wanted
There are a couple cool threads on this.
I'll see if can find one.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-21-2021, 11:07 PM   #3
LostMy65
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=765224
https://67-72chevytrucks.com/vboard/...d.php?t=732404
http://67-72chevytrucks.com/vboard/s...d.php?t=576943
Old 12-21-2021, 11:15 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
If I decide to move my tank to under the bed, I plan on using a 60-66 suburban or panel filler neck and fuel door in the bedside. Welding and body work definitely involved with that idea though
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 12-21-2021, 11:33 PM   #5
Afirehawk1
I found this filler neck and cap
1.5 inch filler neck
I could go on the fender top with a 2.5 inch diameter footprint.
I could bend and weld some aluminum hard pipe from this filler neck and trail beneath the fender well then 90 over with a 1.5x2 reducer fuel hose and then connect to the fuel tank filler pipe which on mine is directed towards the bed side
Looks this may be a clean install and abit custom.
Thoughts?
Old 12-22-2021, 12:19 AM   #6
LostMy65
LostMy65's Avatar
2 inch with a 1.5 inch filler neck
I could go on the fender top with a 1.75 x 2.5 footprint
I could bend some aluminum hard pipe from this filler neck and trailer beneath the fender well then 90 over with a 1.5x2 reducer fuel hose and then connect to the fuel tank filler pipe which on mine is directed towards the bed side
Thoughts?
I think that placed in the correct spot would look spectacular. And no welding required.
Old 12-22-2021, 12:37 AM   #7
cwcarpenter98
Sorry, my suggestion earlier probably won't work too well on the stepside fenders. Should have read the title a little clearer.
Here is what Roll_the_dice did for his stepside: http://67-72chevytrucks.com/vboard/s...&postcount=327
Christian Carpenter
Old 12-22-2021, 10:44 AM   #8
MT65
I have found only 2 limiting factors in building cars and truck,
1–creativity
2 — wallet size
Remember you are building this to please yourself, the rest are just lookers😉😉😉
MT65 is offline   Reply With Quote
Old 12-22-2021, 07:15 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
I was thinking about doing that with a fill grommet and a GM script locking gas cap.
