Old 12-21-2021, 02:58 PM   #1
MikeN
MikeN's Avatar
64 C10 - Lowered 3", New Shocks?
I'm lowering the rear of my 64 C10 short box with CPP 3" lowering springs. Will stock rear shock absorbers still work, or do I need shorter shocks?
MikeN is offline   Reply With Quote
Old 12-21-2021, 03:23 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 64 C10 - Lowered 3", New Shocks?
What shocks do you have mounted? You should be able to find the extended and compressed lengths by the part number. Make sure the new ride height is at the midpoint in the shock travel that there is enough travel in both directions.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-21-2021, 03:25 PM   #3
MikeN
MikeN's Avatar
I installed the current shocks shortly after I bought the truck in 1996. I'll have to crawl under there and look Thanks!
Old 12-25-2021, 12:24 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
I lowered my truck 3" in the back and used regular length Shocks. They seem to be ok but still bounce to much but I have a feeling they have settled into their new position. Today I was bouncing in the back of the truck and it would only go down and up once. I actually have a set of air shocks to put in but they are buried in my storage unit somewhere.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
