Re: 72 C10 for my 25th wedding anniversary
Originally Posted by MDPotter
We had one manifold bolt that was a real struggle and ended up using a helicoil too. On a couple others, we were able to build up some weld and then weld to a nut and that worked well. The combination of heat and actually having something to put a wrench on worked well.
We also have a Terminator on order, but who knows when it will be here.
I hope the terminator works out well …
Did you start on the 1993 ? Or is this for a different project?
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB.
Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, FAST 102/102, FIC injectors,BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project
