Old 10-17-2020, 04:42 PM   #51
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Single to Dual Res Master Cylinder Conversion
Please don't close this thread, and please add it to the FAQs. Thanks.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-22-2020, 07:12 AM   #52
BabyBlue64
Last week I saw my original single Master cylinder is leaking, so I want to do this upgrade also. I found this thread but the pictures in the original write up are gone
BabyBlue64 is offline   Reply With Quote
Old 10-22-2020, 10:23 PM   #53
Captainfab
60-66 Nut
If you are staying with manual drum/drum brakes it is quite simple. All you need is a '67-'70 master cylinder. The front port is the front brakes and the rear port is the rear brakes. Then you will need to add a second line on the back of the suspension crossmember to feed brake line that goes to the rear.
Old 10-22-2020, 10:40 PM   #54
jocko
jocko's Avatar
BabyBlue, I’m still seeing the pictures, they were attached thru this site, not a third party host, so should be visible. Can you let me know which posts you are not seeing the pictures on?
Old 10-23-2020, 02:32 AM   #55
BabyBlue64
Hi Jocko, I mean the pictures of Chief's original write up, where you refer to in post #12.
Old 12-16-2020, 07:13 PM   #56
D'Monsta
D'Monsta's Avatar
My single was leaking so I decided to do this conversion today.. all bled, feels like good pedal, but the brakes barely grab and just kind of coast to a stop no matter how much leg I put into it.. Is there a special way to bleed a dual master or is the 'furthest away, then next furthest, etc.. still the way to do these? I read somewhere else that the front and back from each side should be bled at the same time.. Gotta get this done.. My brakes are worse now than with the single MC
D'Monsta is offline   Reply With Quote
Old 12-16-2020, 08:05 PM   #57
jayoldschool
Moderator
Did you bench bleed the master? Bleed order: RR LR RF LF. Sounds like you have air. Maybe open up both rears and gravity bleed it for a bit, keep topping master. Then do fronts. Then, two person pressure bleed in order.
jayoldschool is offline   Reply With Quote
Old 12-16-2020, 10:24 PM   #58
D'Monsta
D'Monsta's Avatar
Yes, Bench bled the master.. I will redo the bleeding sequence tomorrow.. Probably time for brake shoes too but I want to get the hydraulics in order first..
Thanks..
Old 12-16-2020, 10:35 PM   #59
Captainfab
60-66 Nut
The correct brake bleeding order is LR, RR, RF, LF.
Old 12-17-2020, 03:43 PM   #60
D'Monsta
D'Monsta's Avatar
Thanks Gents.. Got it done.. Nice high. firm pedal.. Will lock up with a firm push now.. I used 3 couplings, one plug, one length of new tubing and some pre-made supply tubes from NAPA.. Nothing fancy but it works great. Peace of mind.. Fixed the E-brake a while back too..
Old 12-29-2021, 05:01 PM   #61
G8rN@te61
I found this thread as I am in the process of looking at changing out my master cylinder and doing some all around brake work. Question I have is when changing out the master cylinder, how do you handle the clutch that operates off it too? I have a '61 btw.
G8rN@te61 is offline   Reply With Quote
Old 12-29-2021, 09:59 PM   #62
LostMy65
LostMy65's Avatar
These threads might help:
http://67-72chevytrucks.com/vboard/s...d.php?t=362375.
http://www.67-72chevytrucks.com/vboa...d.php?t=339335
http://67-72chevytrucks.com/vboard/s...d.php?t=300087
