Old 12-30-2021, 06:25 PM   #5
SilverMiner
SilverMiner's Avatar
Re: '76 np203
Originally Posted by coolpup32 View Post
Parts needed for 205 conversion:
  • Fig 8 bolt pattern
  • drive shafts
  • adapter plate for TH350
One item to add to your list would be the spline coupler required to mate a 28-spline NP205 to your TH350. If you are fortunate enough to acquire the transfer case from a an existing rig then you should get it as part of the package, but I've seen NP205's advertised locally as "complete with adapter and crossmember" which failed to include it.
As 1972K20 pointed out, the fellows at OffRoadDesign.com will have what you need if you go the 205 conversion route. It is a crying shame that the 203 chains are no longer available because unlike most I think that transfer case is excellent. But then I like QuadraJets too, so I'm certifiably weird.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
