Old 12-27-2021, 04:29 PM   #701
FL71C10
Re: My 1970 GMC “Project Splice”
Originally Posted by Kronald_70GMC View Post
Passenger door jamb is done! Working on a bit of filler along the windsheild pillar and along the drip rail. During dry times, I took some better pictures of the emblem placement I'm thinking about. I also cleaned up the lower portion of the fender emblem I had cut up as well as I can have a custom sticker made up for it and use it too. Lots of options available now. The GMC may be a little bit large to use on the glove box door but if I had a sticker made for the "plaque" portion something along the lines of GMC Custom instead of the plastic one that is stock, I might like that better. Might have to see if I can use the wife's computer and do some photoshop. 🤔 Any input is welcome as well. If you guys think I've lost it, let me know. Any feedback is good feedback.
I don't think the GMC letters are too big for the glovebox door at all. I wouldn't do anything else, just the letters.
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 12-27-2021, 04:56 PM   #702
May70
May70's Avatar
Originally Posted by Getter-Done View Post
I am still watching
I am like you slow and Steady.
IDK Kyle is going pretty fast compared to me haha
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 12-27-2021, 05:31 PM   #703
Kronald_70GMC
Kronald_70GMC's Avatar
Thanks for the input. If I do use them on the glovebox, I would definately only use the letters. Good thing I have lots of time to decide what I want to do.
Kyle
1970 GMC "Project Splice"
2017 Yukon Denali (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
Old 12-27-2021, 05:33 PM   #704
Kronald_70GMC
I am still watching
Haha thanks guys! Hopefully more progress coming soon. I have been replacing the garage door opener today. Old one was getting a little scary.
Kyle
IG: kyle_ronald
Old 01-04-2022, 01:22 AM   #705
Kronald_70GMC
I finally got around to making a template for my cargo light off of my dad's truck. I know I should have done it before I did the body work but I wasn't able to access my dad's truck until recently and mine has a cap in the way. Now I have to touch up the filler around where I cut as the heat from cutting cause the filler to let loose a bit. I also got some more filler done across the back of the cab at the bottom.
Kyle
IG: kyle_ronald
Old 01-04-2022, 04:14 PM   #706
upon1
upon1's Avatar
Looks like an awesome build, just looked over your thread. I’m in warman and almost to the same point on my 68. Where did you get your harness? Rpm?
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 01-04-2022, 05:05 PM   #707
Kronald_70GMC
Thank you! Yes I picked it up at RPM.
Kyle
IG: kyle_ronald
Old 01-04-2022, 05:08 PM   #708
Kronald_70GMC
Do you have a build thread for your 68?
Kyle
IG: kyle_ronald
Old 01-04-2022, 08:25 PM   #709
chewychevy67
I live in warman as well with a 67 build. Got a link to pick of your project?
chewychevy67 is offline   Reply With Quote
Old 01-04-2022, 10:06 PM   #710
Kronald_70GMC
Haha yeah this guy is my uncle.^ Was wondering if you guys had met already or not both being in Warman. I'll assume not
Kyle
IG: kyle_ronald
Old 01-05-2022, 01:24 AM   #711
Scurry67
Cab is definitely coming along great. Are you planning on doing the inside of the cab, also?
67 SWB First Build
http://67-72chevytrucks.com/vboard/s...d.php?t=777171
Scurry67 is offline   Reply With Quote
Old 01-05-2022, 09:28 AM   #712
Kronald_70GMC
Thanks man. I will be doing the inside of the cab as well. Lots of fun inside curves there. That should keep me busy for a while.
Kyle
IG: kyle_ronald
Old 01-05-2022, 11:28 AM   #713
Graham57a
Graham57a's Avatar
Kyle your persistence is impressive man. You are building one sweet truck and I can't wait to see the future progress on it
Graham57a is offline   Reply With Quote
Old 01-05-2022, 02:09 PM   #714
Kronald_70GMC
Thanks man! Means alot coming from you, I've enjoyed all of your builds.
Kyle
IG: kyle_ronald
Old 01-05-2022, 02:12 PM   #715
upon1
upon1's Avatar
I’ve got lots but doesn’t seem to look
Like much to look at yet. Lol
Project 55 To Life
Old 01-06-2022, 12:10 AM   #716
Kronald_70GMC
Well tonight kinda sucked. I feathered the filler back in around my cargo light hole and went to set the rivnuts. For some reason or another, the damn things went offset and crooked. One offset left but at least stayed straight to the panel. The other offset upwards and went crooked as well. I could not even get the screw into it all the way. There was no way the light was going fit properly or sit straight. So that was a bust, spent more time trying to remove them without damaging my filler than I did getting them in. Can't win em all. Hopefully tomorrow I can find some more and try again as I only had the two.
Kyle
IG: kyle_ronald
Old 01-07-2022, 01:53 PM   #717
Kronald_70GMC
Alright so I think I now know what went wrong the other night. I believe that the Rivet nuts I had were made for thicker metal. Thus when I riveted them into place, there was too much crumple zone causing them to move on me. I have gotten a hold of some shorter ones and a nice new tool to set them. Hopefully I will find some time tonight to see how they work. You live and you learn.
Kyle
IG: kyle_ronald
Old 01-07-2022, 07:46 PM   #718
Kronald_70GMC
So much better! Turns out that some of the problem was lying with the old Rivet nut tool I was using. As you can see the new tool has a flare to it that acts as a centering guide. Just goes to show, you get what you pay for. Now I just need to get access to a light and confirm fitment.
Kyle
IG: kyle_ronald
Old 01-07-2022, 07:53 PM   #719
Kronald_70GMC
Here is where my theory about the longer vs short comes in. As you can see, the longer ones crimped very poorly compared to the shorter.
Kyle
IG: kyle_ronald
Old 01-08-2022, 08:57 PM   #720
Kronald_70GMC
I borrowed my Dad's cargo light tonight to do a test fit. Couldn't have turned out any better!
Kyle
IG: kyle_ronald
Old 01-09-2022, 07:53 PM   #721
Kronald_70GMC
I got some more filler done on the drivers cab corner today. I'm getting so close to primer, I can almost taste it.
Kyle
IG: kyle_ronald
Old 01-12-2022, 11:39 AM   #722
sakustoms
You just keep plugging away. I've been really lax because it's been in the teens here and my garage has been in the 20s. I don't have the ambition to go out and heat it up. lol
sakustoms is offline   Reply With Quote
Old 01-12-2022, 01:58 PM   #723
Kronald_70GMC
Haha it's been -40°C and colder here for quite some time. At least 2 weeks. This week we are finally getting a break and it is -3°C.
Kyle
IG: kyle_ronald
Old 01-12-2022, 02:32 PM   #724
sakustoms
Ok I'll stop b1tching now. Guess I'm just a sissy. LOL
How do you heat your shop/garage? Mine is a small propane bullet heater and I also have one of those infrared heaters on a stand. I hate the cold. I don't know how you deal with those temp.
Old 01-12-2022, 02:49 PM   #725
Kronald_70GMC
Natural gas unit heaters is how we deal with the cold. We are used to it up here.
Kyle
IG: kyle_ronald
