Old 01-07-2022, 04:31 PM   #1
h00matis
Wheel cylinder link/push pins
Hi all, I'm trying to find wheel cylinder links for my rear axle as they are lost.
The axle I have is the one with the 2-3/4 wide brakes.
I have searched the web for hours and I don't seem to find anything for my needs.
I'm from Sweden so it is not so easy to find them in local stores
h00matis is offline   Reply With Quote
Old 01-07-2022, 06:27 PM   #2
geezer#99
geezer#99's Avatar
Re: Wheel cylinder link
Perhaps you need to search for the right description.
What are ‘cylinder links’?
Old 01-07-2022, 07:05 PM   #3
h00matis
Thats one of the terms i found when searching, push pins is another. It is the rods that are between hte wheel cylinder and the brake shoe.
Old 01-07-2022, 07:27 PM   #4
Mathew21
Mathew21's Avatar
What year and model is your truck? Does it have 11" or 13" drums? I'm guessing 13" with the big brake pads.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 01-07-2022, 09:32 PM   #5
geezer#99
geezer#99's Avatar
OK.
I searched with google images.
Lots of possibilities.
https://www.google.com/search?q=brak...QA&sclient=img
Old 01-08-2022, 03:40 AM   #6
h00matis
Sorry I should have been more specific with the details.
I don't know the year as I bougth the axle from a scrapped car (it might have been 76 but Im not sure), the drums are 11-5/32" X 2-3/4" and it has 5 lugs RWD.
Old 01-08-2022, 09:21 AM   #7
geezer#99
geezer#99's Avatar
You know, pics of your rearend might help a bunch for identification purposes.
Old 01-08-2022, 09:31 AM   #8
bhc41051
bhc41051's Avatar
These maybe?? Brake trust rod?
bhc41051 is offline   Reply With Quote
Old 01-08-2022, 02:41 PM   #9
h00matis
The rear end is in bits and pieces, i took some pics on the backing plate etc IF that helps.
Old 01-08-2022, 02:49 PM   #10
geezer#99
geezer#99's Avatar
I asked for pics because then we could tell what the rearend is from.
Depending on brackets on it, shape of rear cover, pinion style or bolt patterns it might be easier to narrow it down.
You say it came off a car.
What car?
Old 01-08-2022, 03:18 PM   #11
h00matis
Ahh, I see, its from a C10 but i dont know from wich year, I bought it from a guy who already had removed it so I have never seen the truck it self.
It was some years ago but if I remember correctly it was a 1976.
I see that I wrote car earlier but i meant truck
What car?
Old 01-08-2022, 03:34 PM   #12
h00matis
Maybe these will work?
It says it will fit some cars and trucks.
https://www.ebay.com/itm/36067116354...IAAMXQya1Q7S4W
Old 01-08-2022, 03:50 PM   #13
geezer#99
geezer#99's Avatar
At least they’re fairly cheap.
I referenced car because some came with the 5x5 bolt pattern.
Seems you have a truck 12 bolt.
I’ll do some more searching in awhile.
Gotta feed the cat. LOL!
Old 01-08-2022, 04:09 PM   #14
h00matis
, yes and the shipping was reasonable to Sweden.
Thanks for the help to you and all the other people.
