Old 11-10-2021, 08:22 AM   #176
6DoF
6DoF's Avatar
Re: 1958 Saab story
yeah, i watched a buddy do that. bought a used truck, drove it for like 2 days before changing all the fluids, and only one more before the trans was dead.
i opt for the never change it method! if any get low after 100k, i refill with that LUCAS tranny fix syrup to give a little life back to the fluid. that stuff works.
6DoF is offline   Reply With Quote
Old 11-27-2021, 05:20 PM   #177
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Well more progress. I welded the new firewall piece in place. I set up the new wiper setup which looks promising
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 11-27-2021, 05:26 PM   #178
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Well, so much for that idea. I cut down the wiper arm armatures. Plumbed the tubing for the wiper coil out the firewall to make the wiper motor serviceable. I painted the bare metal and welded pieces with epoxy paint. I lowered the body onto the chassis and the wiper tube snapped off. So, there won't be any wipers on this build.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-14-2021, 01:29 AM   #179
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
So I contacted the eBay seller about the wiper setup I bought. They were taking their sweet time responding, so I went ahead and bought a similar kit from brothers trucks. The original eBay seller stepped up and sent me replacement parts, but I wanted to see what brothers had before making a decision. Well the brothers kit is leaps and bounds better. Just looking at the quality of the parts that actuate the wiper arms, I'll be sending the eBay kit back.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-18-2021, 06:58 PM   #180
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Yay, progress! I installed the new wiper setup and mounted the wiper motor on the firewall. The new kit is leaps and bounds better than the first one I got.
Then I had to remember how to reassemble the dash pad, installed the dash speakers and lowered the body down, hopefully for the last time.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-19-2021, 08:18 AM   #181
Father&son56project
Re: 1958 Saab story
Excellent progress! Smart move using the sturdier wiper system kit. That does not look like it would be a lot of fun to replace if it failed!!!! This build is fun to watch.....
Father&son56project is offline   Reply With Quote
Old 12-24-2021, 07:51 PM   #182
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Well now that the wipers are sorted, let's make some floor pans!
First, I cut the top of the step at the corners, bent the top middle section to match the angle of the Saab floor and placed the carpet over it to see how well it covers. Looks like it was made to be there.
Then I made a cardboard template for the section between the step and the rear fender tub.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-25-2021, 05:04 PM   #183
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I finished making the floor board and stitched the entry step to the floor pan
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-25-2021, 05:21 PM   #184
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
Then I made a patch panel to fill in the gap below the dash. I ground all the welds and sprayed everything with epoxy paint, even the underside of the new floor pan.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 12-25-2021, 07:30 PM   #185
dsraven
Re: 1958 Saab story
I'm at the same spot on mine. I plan to use the envoy carpet so the floor on the driver side is sorta like yours but the pass side I cut the envoy floor out where the kick panel starts and will widen it to the old truck door pillar and vent area width.
Old 01-02-2022, 03:58 PM   #186
Madkidd007
Madkidd007's Avatar
Re: 1958 Saab story
Well hell, I guess it’s far enough in I can watch this **** show now
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 01-08-2022, 08:00 PM   #187
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I finished making and welding in the floor board between the passenger entry step and the rear fender well.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-08-2022, 08:03 PM   #188
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I patched the lower a-pillar and installed the carpet and started putting the interior together, starting with the center console. I'm trying to put it together enough to move it under it's own power.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-09-2022, 03:49 PM   #189
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I started stitching up this gap, strengthening the body when it all came to a flaming halt. I've got the truck on the lift so I don't have to lie down and weld. I look up and I can smell burning fabric and see flames inside the windshield. I let the truck down (which took for ever) so I can open the door and extinguish the flames. The juke padding is everywhere under the dash on these things, so who knows what wiring nightmares await me.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-09-2022, 03:52 PM   #190
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I finished the driver's side, spraying epoxy paint inside as best I could along the way. Then I used a spot mirror bracket and an a/c compressor washer to hold the bottom of the inner splash fender.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-09-2022, 08:06 PM   #191
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I finished stitching up the passenger side (no fire this time).
Then I set the front clip on and shimmed the fenders, which closed the gap at the bottom, which means I don't have to modify the core support.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-09-2022, 08:32 PM   #192
dsraven
Re: 1958 Saab story
Great work, that looks way straighter now.
Old 01-10-2022, 07:10 AM   #193
Jason 56
Re: 1958 Saab story
Just read through you build. It’s coming together at a great pace. Personally I think you nailed the stance. Keep up the progress.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 01-10-2022, 08:06 AM   #194
Father&son56project
Re: 1958 Saab story
Looks great. You are nailing a rather tricky swap!
Old 01-22-2022, 07:49 PM   #195
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I cut up the panel truck inner fenders because I needed to repurpose the part with the hood hinge spring.
I think I'll get a top post battery so I don't have any issues with this dude post being so close to the inner fender.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-22-2022, 07:51 PM   #196
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I put the hood on with new hood springs. Everything clears and it latches beautifully.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-22-2022, 08:06 PM   #197
dsraven
Re: 1958 Saab story
Looks great. Side post or relocate for sure. Gotta get that front end hung on there and drive it.
Old 01-23-2022, 08:46 PM   #198
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I mounted the trans cooler with it's own fan and the engine fan today.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-23-2022, 08:47 PM   #199
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I made a bracket to mount the fuse panel
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
Old 01-23-2022, 08:55 PM   #200
gottattooz
gottattooz's Avatar
Re: 1958 Saab story
I bought a top post battery with the positive post Inboard. I used terminal adapters to connect the factory side post connector to the battery. For the negative, I bought a 14 inch negative cable, thinking I'd need to go from the battery negative to the engine block, but the factory battery hold down post was in the perfect spot to connect the ground cable and extend to the battery negative. I'll shorten the extension cable to maybe 5 or 6 inches later. But with the battery connected and most of the ground wires connected, it started right up.
-Josh
1968 Jeep Wagoneer
2017 Suzuki M109R
