Old 01-04-2022, 08:13 PM   #701
60-66
60-66's Avatar
Re: most original 60-66 truck in existence?
Here’s some pictures from one of the Lambrecht trucks. Exhaust and intake were painted on the engine as a unit. This is a 64 c10 with 4 miles on the odometer . This is original paint yet.
Originally Posted by GranPanteraRoja View Post
Thank you! I've look throughout the internet and could never find an answer. Hopefully that will help someone else's Google search
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 01-04-2022, 08:26 PM   #702
cwcarpenter98
cwcarpenter98's Avatar
Attachment 2155825
Attachment 2155826
That's interesting how the color looks to be slightly different. between intake and exhaust. Flash from the camera maybe? Heat affecting the color? Maybe just greasy making it look different?
That little spring on the exhaust flapper doesn't usually hang around all these years
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-04-2022, 09:44 PM   #703
60-66
60-66's Avatar
Paint, hard to say why I guess. All these trucks spent their lives outside just sitting. Nebraska is a lot more forgiving than some areas climate wise . The test of time is all I can say. Certain things were amazing on some and others were pretty bad. The fact that the spring is there and excellent shape is something. Like many of the low mile trucks and cars, it was fun to see these details like paint on the exhaust manifolds still there
Old 01-09-2022, 10:00 PM   #704
GranPanteraRoja
GranPanteraRoja's Avatar
60-66: Do you know about the paint pattern used on the transmission? My bell housing was completely painted blue but if anything was on the Muncie 318 it completely flaked or worn off. I have seen some trucks that had an overspray of blue across the bell housing and then the transmission was just bare and then others who have completely painted the bell housing and transmission blue to match the engine. It may be a plant to plant difference but I wasn't sure what was more common or "correct".
GranPanteraRoja is offline   Reply With Quote
Old 01-09-2022, 10:09 PM   #705
60-66
60-66's Avatar
It’s not a “Plant” thing . Engines were built and painted at the Flint Michigan engine plant and shipped out to body assembly plants . So overspray or bell housing paint was up to the guy doing it that day. If you get the book Chevrolet by the Numbers , it tells you what order Flint painted the engine and with what components were on the engine during the paint process. What it doesn’t say is 6 cylinder vs v8 .
Old 01-09-2022, 10:14 PM   #706
60-66
60-66's Avatar
Also, the transmission from what I’m seeing is either bare casting or painted black from what I’ve been able to document from original trucks. There’s another person claiming that transmissions had red primer on them , but I have never seen that , just on transfer cases. Your best example is your own truck if those details can be uncovered by careful cleaning. Transmissions were not on the engine when painted.
Old 01-10-2022, 09:47 PM   #707
GranPanteraRoja
I appreciate the insights, thank you for the help. I enjoy learning the history of these trucks as much as I can and all of the differences that make each unique so I will definitely pick up your book recommendation. I hope to share my build soon on these forums, I'm not a complete factory purist but definitely prefer stock inspired restorations.
Old 03-20-2022, 07:28 PM   #708
sodly
sodly's Avatar
Appears to be a beaut!
https://www.ebay.com/itm/30440356120...47ca%7Ciid%3A1
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 03-20-2022, 09:08 PM   #709
chtr65
Great truck. After viewing the eBay listing I must confirm two things. Chips in windshield confirms this truck once lived in Montana. Second, as someone here previously mentioned, these trucks left the factory with rust in the lower tail of the front fenders. Sodly, thanks for posting.
chtr65 is offline   Reply With Quote
Old 03-20-2022, 09:30 PM   #710
karlbenz
I have a 66 gmc that is the most original I've ever seen. Wiring harness is still intact. v6 4 speed. radiator is gone. other than that under the hood is pretty much intact. The body is bad though
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 03-21-2022, 01:06 AM   #711
oem4me
Looks like it's worthy of a closer inspection. Suspiciously clean wheels and other concerns, like remnants of green paint on bedwood, when claimed "has had no paintwork".
Old 03-21-2022, 09:03 AM   #712
Rubbertiredtramp
That 63 is a very nice looking truck, with just enough wear and tear to make look only a few years old, which is the look that I really like. And it has a drive train that I would really want, V6 and 4 speed, being a Canadian means that truck would probably cost me twice the 43K. I think I will keep the one I have the colour isn’t as nice and motor isn’t as desirable, but I have 10K into it, not 43+. Another thing we have to consider is that 10 years from now, what are these trucks going to be worth, maybe zip.
Rubbertiredtramp is offline   Reply With Quote
Old 03-21-2022, 09:15 AM   #713
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wonder Why it Has Rivets on Vin Tag?
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 03-21-2022, 10:38 AM   #714
forestb
forestb's Avatar
It has black rear wheel tubs is that stock?
forestb is offline   Reply With Quote
Old 03-21-2022, 07:00 PM   #715
factorystock
factorystock's Avatar
Rivets are also used in this super low mileage '62 GMC. Probably same assembly plant, my guess Pontiac, Michigan.
factorystock is offline   Reply With Quote
Old 03-21-2022, 07:04 PM   #716
factorystock
Fender tubs are also black on this super low mileage '62 GMC, probably same assembly plant, my guess, Pontiac Michigan.
Old 03-21-2022, 07:14 PM   #717
factorystock
I agree, has some paint work on the wheels. Wheel color should be an off white, not a gloss white color. Color of inside of bed doesn't quite match the color of the outside for some reason. Needs closer inspection. But everything else looks pretty good, interior and exterior. What's nice about GMC 1/2 ton V6, it came with a 3.07 ratio and a rear leaf spring set up. Color appears to be a GMC only color, Terrace Blue
Old 03-21-2022, 07:21 PM   #718
factorystock
Thanks for posting Sodly, excellent addition to this thread.
Old 03-21-2022, 09:04 PM   #719
Steeveedee
Who Changed This?
Steeveedee's Avatar
My understanding is that rosettes were used then, and these appear to be pop rivets. I wouldn't touch that truck with a 10 foot pole without seriously good documentation.
~Steven
Simi Valley, CA
Old 03-21-2022, 09:08 PM   #720
denverslim
My '66 C-20 is pretty original. I bought it from the original owner. He thought it was too white when he got it from the dealer so he had the dealer paint the trim insets red.
I have repainted the boards in the bed and replaced the split rims with later model wheels. Other than that she's an original. Keith
denverslim is offline   Reply With Quote
Old 03-21-2022, 11:03 PM   #721
Steeveedee
Who Changed This?
Steeveedee's Avatar
Red makes it go faster. That is one nice looking truck!
~Steven
Simi Valley, CA
Old 03-22-2022, 03:50 PM   #722
EdWeeds
I am new to this forum as I just purchased a "bone stock" 66 C10 SWB Step side. Somewhat rare MT 327. Seller/dealer said that a restoration was done in 2019, which appears to have been primarily cosmetic, repainting the frame and body (in original color) etc. Not sure where the fender badges are, maybe aftermarket replacement fenders. Original wiring has given me fits chasing down shorts and bad grounds. Other than a complete tune up and running some dedicated grounds I am probably going to leave it as is. Maybe power steering as tight turns are an effort.
EdWeeds is offline   Reply With Quote
Old 03-22-2022, 05:28 PM   #723
60-66
60-66's Avatar
I cant focus, either on my computer or phone well enough to tell if thats actually a rivet or the factory spot welded tag . Wish we could get a closer look. If thats what your seeing , fine but when these were welded , sometimes it left a bigger impression in the tag. That GMC script on the tag cant be reproduced . Ive tried . One of my tags was severely damaged so I just straightened it the best I could
1960-1962 GMC yes , round rivets . 1963-1964 was spot welded on GMC. 1964 they discovered these tags were falling off do to water getting behind them and freezing popping them off. This was mainly on cars of the era, not so much trucks. Then later they started using either rivets in 65 and some a combination has been found of one round and one Rosette .They went to all rosette rivets completely in 1966 . This is GMC only . Chevys were spot welded 60-64 , 65 round and rosette, 66 all rosette . This does have the P in the vin for Pontiac.
Rosette was not used till 1965-1966
Old 03-22-2022, 05:36 PM   #724
60-66
60-66's Avatar
That paint in the bed , doesn't make sense ? Why is it not on the inner fenders ? Pontiac didn't paint the wood body color . I agree on the wheels , they definitely look redone and hubcaps look very nice .
Old 03-22-2022, 06:37 PM   #725
Steeveedee
Who Changed This?
Steeveedee's Avatar
Huh, I learned something today! Thanks!
~Steven
Simi Valley, CA
