Old 01-16-2022, 07:42 AM   #7
dennislbrooks
dennislbrooks's Avatar
Re: 1951 Crosley Sport -- how?
I will let all know when I get the Motors if it tells. As far as removing the hubs and knowing of consequences:
1) Removed cotter key and axle nut.
2) Shot hub/taper with liquid wrench
3) Next day used blue flame on hub near taper
4) Used a 3/4" thick strap across castle nut on axle left a little over 1/16" gap between nut and hub using 1/2" fine thread bolts across 2 opposite lug threads -- they are 4 lug
5) Slowly somewhat evenly tighten bolts -- need some tension
6) If needed give strap a light tap but was not needed. Both sides acted the same.
7) Do not gorilla anything. Use more liquid wrench and blue flame.
As I understand most of these hubs crack because of the incorrect installation of the square key on the taper then tightening.
Since they are 1/4" keyed I used never seize on the tapers to reinstall.
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
