Dakota Digital American Autowire
Which Wires Do I Need And Which Should I Cut out Of The Way?
Trucks a 69 c10 I Noticed a Gray Dash Light Wire… Needed? Thanks Posted via Mobile Device |
![]() Join Date: Mar 2015
Re: Dakota Digital American Autowire
Description is A little vague? Can you elaborate?
One gray wire, I can think of, is the one that powers the tilt column light. Others are the heater controls illumination. Cheers. |
I just installed the AAW harness and Dakota Digital gauges. If I understand your question, I did not use the Temp or Oil Pressure wires on the harness as the gauges had their own. Pretty sure I used everything else though. It was just a matter of running the wires to the control box instead of pinning them out to the factory gauge plug.
#4 | |
Just Wondering What You Did For Constant Power And Accessory Power? Not Sure What The Dim Is For As Well If I Need The Tan Brake Wire? Thank You Posted via Mobile Device |
