Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 01-19-2022, 04:24 PM   #201
Captainfab
60-66 Nut
Re: '67-'72 Power Brake Booster Bracket With Hydraulic Clutch Conversion
If you use the factory booster mounting brackets, that booster might fit. If you use the booster mount that comes as the regular production part, it will not fit. The '69-'72 has the least room for a booster out of the 4 hydraulic clutch conversions that I fabricate. If you inform me of your intentions ahead of time, I will delete the booster mounts from the base plate at a cost reduction of $25.00.
Originally Posted by 67ss&99ss View Post
Captainfab, I'm interested in one of these kits for my truck. I have a 1969, but have converted it to power disc brakes. I measured the booster last night and it appears to be about 10.75-11" in diameter. I've also attached a few pictures for reference. Will your kit work? Do you need me to check anything else to verify fitment?
Old 01-20-2022, 10:22 AM   #202
67ss&99ss
Andy
Sent you an email.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 01-21-2022, 10:01 PM   #203
Captainfab
60-66 Nut
Emails replied to and payment received, thanks.
Old 03-17-2022, 07:15 PM   #204
Captainfab
60-66 Nut
Here is a link to my new website and online store where you can see and purchase all of the products that I fabricate for the '60-'72 GM trucks.
https://customfab-cda.com
Old 03-22-2022, 10:03 AM   #205
67ss&99ss
Andy
Originally Posted by Mbeef61 View Post
Hey capt. Received my kit today. Fast shipping. Thanks.
I received a different interior mount than I have seen in the pictures. Just wanted to make sure it’s correct… I will work on my mock up this week and post some new pictures if so.
Thanks again
Did you get around to taking pictures of your setup? Mine looks like this too and there is nothing to reference. It looks like the standoffs will hold it off of the firewall.
Capt. Fab,
Do the welded on nuts act as a spacer to get the stroke length of the linkage correct for the master cylinder? The image to the right is of another truck in this thread and it doesn't have this style. Also, does the blackened steel sleeve supposed to have threads in it? Mine does. I would assume this should be a thru hole and only serve as a spacer to gain the right alignment for the heim joint.
Old 03-22-2022, 10:47 PM   #206
Captainfab
60-66 Nut
All of the parts you received are the current production parts and are correct for all 4 of my hydraulic clutch conversions. I changed the design several years ago and simply have not had the time with working 80hrs/7 days a week every week every month, to mock up and take all new pictures to replace the pics from 10+ years ago. Two of the pics on the pages included with your kit, show the new design.
Yes those coupling nuts welded on the back of the pivot block must be there.
Yes the threaded standoff is supposed to be threaded. It is threaded 3/8"-16 on one end and 5/16"-18 on the other end. It bolts to the clutch pedal with the 3/8"-16 x 1" bolt once you drill the hole and the heim joint bolts to the standoff with the 5/16"-16 x 1" bolt.
Old 04-15-2022, 08:07 PM   #207
gpgofast
Just received my kit. AWESOME quality and craftmanship. Can't wait to get my LS 6.0 swap in.
gpgofast is offline   Reply With Quote
Old 04-15-2022, 09:59 PM   #208
Captainfab
60-66 Nut
Thank you for the kind words. I appreciate the business.
Old 04-15-2022, 10:24 PM   #209
gpgofast
For anyone on the fence for buying one of your kits, the engineering, fit, and finish along with the shipping left me very pleasantly surprised. Often I am let down today, but your kit is top notch. Thank you for making quality stuff.
Old 07-13-2023, 08:12 PM   #210
57taskforce
All about them K’s
57taskforce's Avatar
Captain, I’m ready to purchase another kit, I will PM you the details.
Tyler
Old 07-13-2023, 09:02 PM   #211
Captainfab
60-66 Nut
I will reply to your PM.
All of my products can be seen and purchased in the online store at our website. Here is the link.
