Old 09-06-2021, 05:42 PM   #201
65Custom
Re: 65Custom Build Thread
Originally Posted by JonnyNewton View Post
Glad to see you're back on it. I just dug my 65 out that my dad and I semi restored 19 years ago and have begun to work on it again also.
Thanks hoping to keep up the momentum and get it going.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=366677
I must be
65Custom is offline   Reply With Quote
Old 11-12-2021, 08:42 PM   #202
65Custom
So a little more working getting done, The door bottoms being replaced roof is in place needs to be spot welded back in place.
Also fitting the doors after the repairs.
My Build Thread
I must be
Old 11-13-2021, 02:36 PM   #203
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice work, thanks for the updates.
Old 11-22-2021, 01:56 PM   #204
65Custom
Roof panel is now permanently in place, spot welded in place this week.
My Build Thread
I must be
Old 11-22-2021, 02:14 PM   #205
The Rocknrod
Moderator
Good job on that roof.
Old 11-23-2021, 11:17 AM   #206
88Stanger
88Stanger's Avatar
Nice work on the roof!!!
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-19-2021, 07:40 PM   #207
65Custom
Making more progress, getting to the fenders.
My Build Thread
I must be
Old 12-19-2021, 07:43 PM   #208
65Custom
Patch panels really suck for anything these days, they just don't have the correct feature lines had we had to cut them up pretty good to keep as much of the original feature line as possible on the fender otherwise it just would not be right and most people may not notice these little subtle things but attention to the details is what makes the difference.
Don't mind the large gap at the door, the door skin was a 1/4 inch short so we have fill that in with a small strip, as I said none of the repair panels are right these days. We couldn't use the whole door skin as door handle notch was not stamped correctly and the door handle would have been in the wrong location along with it not being stamped correctly, the handle would have had issues being installed after it was painted if we didnt catch that or we would have had to do a lot of work just to fix the door handle in the right place. So we opted to keep the top half of the original doors.
My Build Thread
I must be
Old 12-19-2021, 08:07 PM   #209
65Custom
Keeping the drip rails too, had to replace them. fortunately I was able to get a couple of good ones to weld back in place, if you do this be careful and check the length of the ones you have vs the ones you replace mine were not as long as the ones from the donor truck, so we had to make some adjustments to get them to fit.
Also got a dent in the B post knocked out a little looks better
My Build Thread
I must be
Old 12-20-2021, 11:55 AM   #210
LT7A
Wow, an eight year hiatus and you came back! How cool is that. Glad that you are getting such good progress.
LT7A is online now   Reply With Quote
Old 12-21-2021, 11:33 PM   #211
65Custom
Yep it has been a while. Mainly having no real good place to work on it, moving in the last year and building a new home and shop, but I have the desire to finish her so hopefully I can keep the momentum going. I have a new shop at the house now 24x30 for working on her so when she comes back I wont have any excuse to not work on her.
My Build Thread
I must be
Old 12-30-2021, 08:26 PM   #212
65Custom
A little more progress, not much else to say at this point.
My Build Thread
I must be
Old 12-31-2021, 01:17 AM   #213
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Your patchwork skills are impressive.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 01-02-2022, 10:58 PM   #214
65Custom
Thanks Man, but I can't take credit for the most recent work, that is being done by my best friend, I needed a place to keep it while I was building new home and shop, rather pay him to work on it than paying for storage.
My Build Thread
I must be
Old 01-10-2022, 10:04 PM   #215
65Custom
Few more pics of progress. Fitting more panels and finding out how bad these trucks fit together lots of adjustments and shims and rework to get body lines halfway decent.
My Build Thread
I must be
Old 01-22-2022, 12:26 AM   #216
65Custom
Bed is on and checking to make sure the body lines are lining up had to add some shims to the cab mounts to get things in line.
My Build Thread
I must be
Old 01-22-2022, 04:02 AM   #217
Braunschweiger
You're making good progress, great work
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 01-22-2022, 12:18 PM   #218
pdxhall
pdxhall's Avatar
Nice work. I agree on the fact that these trucks did not fit together that great from the factory so it makes our job that much harder.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-22-2022, 06:11 PM   #219
65Custom
yeah and piecing things together from many different trucks also doesn't help much either. A lot of the lines need massaging just to get lines to look decent.
I bought polyurethane cab mount bushings and I have decided that they may be part reason for the extra cab shims to get the lines straight so I ordered a set of rubber bushings also should help with the ride too, early on when I bought the poly bushings I was more concerned with longevity as now Im much older I would prefer a better ride also to ensure the bushing are the correct size as well
My Build Thread
I must be
Old 04-16-2022, 07:18 PM   #220
65Custom
I have Been gathering parts for a while now and I got my trim in this week all of it seems to be decent. I didn't want to pull all the side trim out due to it being tightly packed in a tube, it was little hard to just pull it out where I could look at some of it, also a couple of shots of something to come.
My Build Thread
I must be
Old 09-28-2022, 06:05 PM   #221
65Custom
More goodies
My Build Thread
I must be
Old 09-29-2022, 10:43 AM   #222
joesscamaro
Nice! Looks like you've got some quality parts going on the truck. Look forward to more updates.
joesscamaro is offline   Reply With Quote
Old 10-12-2022, 10:28 PM   #223
65Custom
Thanks, been in the works for a long time and things are coming together, Figured since I gone this far might as well do it right for how I want to build it.
My Build Thread
I must be
Old 11-22-2022, 09:41 PM   #224
65Custom
A few pics of the work going on
My Build Thread
I must be
Old 11-22-2022, 09:50 PM   #225
65Custom
Stake pockets got filled, and filling in the tailgate chain mounts and holes, obviously still a long way to go but a good start
My Build Thread
I must be
