Can I cut these off the block?
Went to throw a 2006 Tahoe 5.3 into the 1967 k10 and these little nubs are in the way,can I cut them off? Mainly the one with the webbing cast into is concerning me.
Re: Can I cut these off the block?
I would say you can as long as you don't get too carried away. But wonder why you would need to? I have never had an issue with them or even heard of anybody that has had this problem.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
In my research prior to swap I never seen or heard of this issue either but it is keeping me unable to drop onto the pad on one side when the other side has landed.
low n' slo
![]() Join Date: Mar 2009
are these slider mounts your using?
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Moderator
![]() Join Date: Jun 2017
How close is the rear of the valve covers to the firewall?
It looks like the engine is way too far forward.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
low n' slo
are the k10 mounts different? with my dingo sliders that casting is almost 2 inches away from my engine mount
low n' slo
so are those the v6 mounts too?
if i remember right those mounts either need to be moved to the v8 holes or you need v8 mounts. someone else can chime in to make sure but it was something along the lines of that.
![]() Join Date: May 2015
V6?
May need v8 mounts,, the v6 mounts may be what's causing the issue
I'm thinking that may be the issue, I cut of the nubs but now it looks as if the motor is not going to have room at the firewall. I'm still running the Sm420 and Rockwell transfer case, tomorrow I might try removing the motor mounts and seeing if I can slide it together at a lower pitch.
| Bookmarks |
